missing sports channels look here
  • n1ck1ee
    • 43
    hi if you have missing setanta or sky premier you need to press tv on your remote then goto bics channels or any other strange names they may be under and go on to each channel then rename then as appropriate then sort into favorites
    if this helps click thanks
    NEW AUTO CHANNEL UPDATES AT TOP ON STICKY THREADS
    thank the person responible
    the setanta sports channels are now on frequency 283.00mhz.
  • PVR5000
    • 15
    How do you rename them?
    • n1ck1ee
      • 43
      go onto channel you need ie setanta sports 1 whilst viewing channel press menu scroll across to channel manager then press blue button then green then remane using the keypad that pops up goto favorites manager to put into groups ie sport
      click thanks if this helps you
      • alan20
        • 7
        found all my missing channels in those new bics after rescan
        • EurovoxK
          • 35
          Good work...
          • dazavich
            • 28
            Couldnt find them in mine, i only have 2 bics channels, 1 & 2
            Anyone help?
            • jckw
              • 760
              do u no wot channel boxing is on tonight
              we are all learning each day
              • Paul R
                • 19
                would also like to know this
                • dazavich
                  • 28
                  There on ppv events on mine, hope this helps
                  • f1eddc
                    • 63
                    boxing
                    Just do an Autoscan
                    check through your channels, try channels numbered TVCH3 or TVCH4, any how it should be showing the preview to it now.
                    Only problem is it may change channel number so just scan again to find.
                    Hope its helped if so please click the thanks button.
                    • n1ck1ee
                      • 43
                      f1eddc can you tell me how to do a manual scan
                      thanks in advance
                      • f1eddc
                        • 63
                        Manual scan
                        Press menu on your remote go to installation press user installation pick the frequency number of the channel u want to scan - tick it using ok button (u can get the frequency of the channel by pressing info 2 times on that channel displayed at top of screen) then press blue for the manual scan and that will pick up all the channels with that frequency. Hope that helps.
                        • jckw
                          • 760
                          the fight is on tvch10 re scan and its there
                          • n1ck1ee
                            • 43
                            can anyone help with a sagem dbox that had sportster image on it at one point pleaseidiots guide would help
                            • Ropey
                              • 4
                              Hi, done an autscan but still cannot get Setanta sport channels.
                              My scan freq starts at 322Mhz.....how do i manually scan for freq 283Mhz (as apparently this is the new Setanta frequency)
                              Any help appreciated...thanks
                              Found how to manually scan & tried Freq = 283 Mhz, Symbol = 6.952 and Modulator = Qam64 ......no luck signal too weak & scanned no channels !
                              Please help !
                              Got it & it works - Freq = 338 Mhz
                              If this has been useful then don't forget to THANK ME !
