heys guys, wondering if anyone can help. I installed the firmware updates for my box not knowing that my box is a clone. Now i have messed my box up and am unable to do anything on it. i am waiting for the new clone firmware to be released but im wondering whether that will fix my box, or will i have to throw them away. i have tried installing the old clone firmware, but nothing happens. Any help would be greatly appreciated
eurovox 2006 blue clone
right stay with me on this one, the boxes are probably clones, flash with your last flash 21/04/08 I think, then plug in as normal, cable feed, power, but instead of using the scart, use an aerial( analogue ) the old fashioned way of connecting them to the television, you should use the channel search on your tele to find the box, once you have found the box go to the menu 1004 for the code, tv settings,heys guys, wondering if anyone can help. I installed the firmware updates for my box not knowing that my box is a clone. Now i have messed my box up and am unable to do anything on it. i am waiting for the new clone firmware to be released but im wondering whether that will fix my box, or will i have to throw them away. i have tried installing the old clone firmware, but nothing happens. Any help would be greatly appreciated
MULTI,
4.3
RGB
FULL FRAME
ON
PAL B/G
40
save and exit
now unplug aerial, reattach scart and hopefully you've sussed it, remember the aerial goes into the tv vcr socket not the one below your cable feed. cable feed should be in as well
go to factory default, powerscan, and hope all is well.
unfortunatley you'll have to wait for a new flash but at least your up and going and your box isn't bricked.
remember all the normal leads are in apart from the scart, which you replace with the old(anologue coax lead) I posted this on another site and it helped a few people out, hope it helps youComment
this works great just got 2 boxes up and working thanks for great info will pass this on to others that have dead boxesright stay with me on this one, the boxes are probably clones, flash with your last flash 21/04/08 I think, then plug in as normal, cable feed, power, but instead of using the scart, use an aerial( analogue ) the old fashioned way of connecting them to the television, you should use the channel search on your tele to find the box, once you have found the box go to the menu 1004 for the code, tv settings,
MULTI,
4.3
RGB
FULL FRAME
ON
PAL B/G
40
save and exit
