Is there anyone can help
  • hypnomt
    Hi i understand new codes are available for eurovox can someone help me with how to do it and where to get them from? Desperate
  • dasteph
    • 1293
    depending on what eurovox you have simply update firmware, all firmware variants are posted onthis site.
    • clit-eastwood
      • Aug 2008
      • 339
      either look in the download section, or go to forum list, and you will see lots of stuff in there ok?
      • Bravo111
        • 69
        This guide is intended for use with the Eurovox but the equipment required is the same for flashing other boxes. The only differences will be with the relevant box firmware and its loader software.
        Get the correcr fix, may be on this site if not pm me and i can send you the link. I used red patch works fine.
        Lets kick off then.
        WHAT YOU NEED:
        1. Null Modem Cable, Maplins
        2. Serial to USB Adaptor, again Maplins
        The above adaptor assumes that you want to use a laptop to do the job; as most recent laptops do not have a serial port, you must purchase the adaptor.
        The Serial to USB adaptor will come with a drivers disk. So install this before we go any further and follow on screen instructions.
        Connect the adaptor to the USB port on the laptop. Connect one end of the the Null Modem cable to the Adaptor and the other to the serial port on the Eurovox.
        Download the correct version ( box dependant )of the software from the DOWNLOADS SECTION here ( you need 5 posts before accessing this area )
        The file will have to be extracted. Use winzip or winrar for this procedure ( Very easy )
        Ensure the Box is powered on. You can leave connected to the TV if you choose.
        If you have your channels set up in Favourites we will back them up before flashing, although in some instances, the new update will not affect stored channels if your firmware is not too dated.
        Anyway, go to the file which you extracted and start the application. ( It will be named UFL_MaxV_Kuro V........ ) Your first action will be to upload channel data. Select a name and a location for the file and save it. It is at this point you will be alerted if the box has connected with the PC. If it has not, do the following:
        Go to Desktop / Right click" My Computer" / Select Properties / Hardware / Deivce Mgr / Ports & Com Ports. Now select the next option to appear , in my case it's prolific serial to com port. Now select Port settings / Advanced / Change com port to 1,2,3 or 4 / OK / Exit .
        Go back to the loader screen and you should now be able to communicate with the box.
        Following channel data backup, you must now download the firmware to the box. Again, it is indicated on the screen and very easy to do. Once initiated, the box will display DNLD message and a progress bar will appear on the laptop screen. Allo to complete fully ! Do not disconnect until UPDATE SUCCESSFUL message appears on the screen. This can, in some cases, be 30seconds after 100% has been reached on the progress bar.
        Finally, download your channel data and the operation is complete.
        Hope this helps ;-)
