updated a clone box with new software
  • dazlb
    hi there hope some one can help i have flashed a clone eurovox blue max v. did not download the file from here other wise i would have seen not for clone boxs. now my box does not even come up on the tv it goes through the boot up process and the channel number comes up on the screen. i press channel up and it does nothing also have put tsop back on the box that has done nout. is there a differnt tsop for a clone box can any one help cheers
  • satsmo
    • 6397
    You need to flash with the blue clone safe firmware, (you will find this in downloads). It wont AU but it will get the box back and working. Do a factory reset after flash and scan again. The you will need to manually update the keys.
    • dazlb
      tried that same thing on two boxes still wont come up on tv. can power off and on but wont let me change channel up and down just stays on the same one. any other ideas cheers
      • satsmo
        • 6397
        After you reverted. Try VCR RF output via a coax lead, (do not use scart). Then tune channel in on TV until you see the menu. Do a factory reset and powerscan. After that your scart output will work and you will see all channels.
