digivox ireland
  • Brett69
    • 11
    digivox ireland
    Help guys! I live in Lahinch co Clare need to get my Digivox-t up and running again need firmware or new codes can anyone help. on NTL MMDS
    if i have codes how do i install them cos i have been given 2 lines of number sequences do i install 1 line or both lines at the same time?
    Last edited by caveman_nige; 21 December, 2008, 02:49. Reason: moved from Eurovox section
  • caveman_nige
    • Feb 2008
    • 4920
    have you tried any of these
    • bassman
      • 14
      I got mine running again, just inputting the new c*des from keym*aster, you should get running again using info attached, they haven't done a new firmware yet as far as I know
      • Brett69
        • 11
        yes i tried reinstalling v3200 and also uk fix but neither worked
        thanks for the info.
        • Brett69
          • 11
          thanx bassman will give these a go a little later have to go out at the mo so will let you know how i get on later.
          • Brett69
            • 11
            hi bassman tried the c*des i have but they do not work any chance you could mail me the ones you used in a PM cheers.
            • bassman
              • 14
              Sorry meant to pm
              • Brett69
                • 11
                Sorry meant to pm
                Those were the codes that i had.Tried them twice with no luck.
                thanx anyway matey will have to keep looking.
                • pudzy
                  • 206
                  ok brett, first of all your on cho8us mmds if you live in that area, so input cho8us key code , you must be new to this surfing area
                  • Brett69
                    • 11
                    Thanks,yes I am new to the area but have tried inputting the c*des for both NThell and Ch8rus with no luck.The c*des that are about are they for the Digivox-T or other Digivox models? If you have any other info that you think might help could you PM me please:
                    • pudzy
                      • 206
                      if you have digivox t code for ch8rus code will work, press menu, press system info, type 1969 press nagra , then input code, press ok to save then exit, starts with ce , if you try that one again
                      • pudzy
                        • 206
                        if you have digivox t code for ch8rus code will work, press menu, press system info, type 1969 press nagra , then input code, press ok to save then exit, starts with ce , if you try that one again ,
                        • wozzo
                          • 198
                          Inputting the codes is only temporary, they keys will roll every day or two.
                          A fix is needed for the terrestrial boxes, one was not made as they dont use MMDS in the UK, so when it hit them 2 weeks ago no such fix was made.
                          • Brett69
                            • 11
                            thanx your a diamond! worked this time back up and running.
                            • caveman_nige
                              • Feb 2008
                              • 4920
                              nice work guys, good to hear you up and running again..
