the box pvr
  • eire
    • 12
    the box pvr
    hi,the prerecording isn't working help,ciao eire
  • jbvid
    • 261
    Hi
    More info needed, which make / model / version of PVR, which software on it, have you formatted the Hard drive and do you mean it won't record from EPG timer setting and does it record from the remote control record button???
    jbvid
    • eire
      • 12
      hi, the model is the box pvr dual record pvr e.ver4.506 15 oct 2007, i load the new fix the box pvr.3105,wont record from epg timer setting, i did format the hard drive,record from the remote control ok, also put back the factory setting same problem, ciao eire
      • jbvid
        • 261
        Hi
        Has your hard drive recording ever worked? If not try another hard drive? If ok there is much newer firmware with AU for the box PVR twin tuner dated 21/12/08 in the Downloads section
        jbvid
