The keys rolled again?
  • nodular
    • 4
    Just got back from a wee jaunt away to pitlochry an the cable channels have gone again. Anyone got new keys?
  • thommo
    you dont need keys anymore there is an AU fix, check in my signature below there are some links, you want the AU fix one.
    • 6666a
      • Feb 2008
      • 9
      loaded the AU Fix,but not updating auto
      why its not working as i loaded all three files in keys folder ,restart then no .pic..why.then i manually changed rom7 key its working.why AU fix not working ..???
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        You need to set the config file to auto update.
        Ive recently installed the "nagrarom7.bin" file.. I was wondering how will I enable the AU { 02 } in the camd_cfg file and mg_cfg file? Where are these files located? Cheers
        • smirnoff_rules
          • 8603
          did u change the auto update function ? u need to turn that back on
          • rob6007
            • 152
            guys does the keys work if you put them in manually still . waiting to see dream box master to help show me how to do th perm fix
            so can put the new keys in manually or not
            • Devilfish
              Administrator
              • Feb 2008
              • 7872
              If you have the new keys, they can still be entered manually, yes.
              • rob6007
                • 152
                is there new keys availible . does anyone have them .
                • Devilfish
                  Administrator
                  • Feb 2008
                  • 7872
                  Keys won't be posted any more because there is an auto update fix available.
                  Posting keys will get the forum in trouble so we don't allow it.
                  • father ted
                    • Feb 2008
                    • 1389
                    where did you get them from b4?did you get them where everyone has a meal?
                    • rob6007
                      • 152
                      got them from here b4 . no probs will do without until i get fixed properly . thanks guys
                      • aftermath
                        • 4345
                        Its pointless putting the keys in manually anymore mate unless your desperate. They will probably just roll again tomorrow, I heard Ireland rolled 3 times last night.
                        • rangers71
                          • 60
                          see guys a think ur better off with the old sammy boxes or even older pace box and the old atmega a stand by it but a suppose not every 1 is in a cable area
                          • gingerninja
                            • 168
                            hi there devilfish further to a recent reply to myself and others
                            i have been reading some threads and noticed shadys noobs guide says transfer to var init file but this is incorrect. i believe i have transferred files to var file in error but still no channels
                            this thread mentioned by thommo that no keys are required and there is another fix
                            can you clarify please
                            • Devilfish
                              Administrator
                              • Feb 2008
                              • 7872
                              This thread should sort you out.
