Digivox Channels
  • daz24c
    • 380
    Digivox Channels
    hi every1 i need some advice.i recently bought a digivox xl and updated it with the latest firmware but the channels are ion a stupid order!! is there any way to sort them out? starview channel editor maybe?please help!
    Daz
    Thank Me If I Help You
  • wernley
    • 113
    do a factory reset in factory settings on menu then auto scan for cannels the password for factory reset is 0000 hope this helps
    • daz24c
      • 380
      if i do a reset wont it just put the channels bk in the same order when i search again?
      • wernley
        • 113
        yes but will auto sort,when you flash again do a factory reset then scan 4 channels its in the how 2 section do a search
        • daz24c
          • 380
          ok mate l giv it a go cheers
          • daz24c
            • 380
            its put them in exactly the same order.
            ETVS channels to start with
            i want BBC1 first
            • shady77
              • Aug 2008
              • 982
              think im right in remmebring that xl autosorts into bouquets. think theyre under the fav button.
              • daz24c
                • 380
                so is there no way i can edit my channel listings?
                • bugaloo41
                  • 1598
                  daz you can edit through channel edit function can you not ( from memory you can certainly do this with the silver version).
                  • cactikid
                    • 12017
                    as far as i remember xl channels are hard coded meaning u cant swap around.
