Digivox XL will not flash
  • flemmingsjordan
    I myself have a Digivox (silver) and have successfully updated the firmware with the latest AU fix.
    A colleague has a Digivox XL which I said I would update for him.
    Using the correct Digivox XL AU fix I proceeded only to find the following:
    Using Downloader I click "Download". The progress bar on the PC doesn't move and Digivox XL display does nothing - just says "On".
    It then fails on the PC and the Digivox reboots.
    Could this be a simple case of a wonky serial cable maybe?
    I've tried to flash with older firmware just in case the file was damaged. I have also tried a factory reset.
    Any ideas? Any help would be great.
    Thanks,
    Eoghan
  • bugaloo41
    • 1598
    If your box flashed with the same cable its unlikely its that. I have had a cable that only worked in my com 2 that might be worth a try. I know it sounds silly mate but the box is defo on when your trying to flash?
    • flemmingsjordan
      Yep - defo on.
      I might pick up another cable just to see. Only got 1 com port. Thanks for the help though!
      • bugaloo41
        • 1598
        mate it might be worth trying doing a box to box transfer. all you are doing is flashing the image of your box to his. you can also transfer channel lists this way. worth a try and that way you might be able to establish if its the cable.
