LOCKED DDigital By Mistake, How do i fix it now?
  • Anup509
    • 77
    Hay people, i got Ddigital, nd i locked it by mistake, how do i unlock it now? Please Help me soon as possible please...
  • wernley
    • 113
    bit more info on locked please then we can help
    • bugaloo41
      • 1598
      Initially posted by Taz at WM
      1. switch off the DDIGITAL box(BACK SWITCH)
      2. connect all cables(power and rs232 cables)
      3. open the loader on your pc
      4. click code the send
      5. press open and the file you want to load into the DDIGITAL reciver
      6. make sure the port number is correct one you use(port1 or port2)
      7. press start button and quickly switch on the DDIGITAL box at the back.
      8. reciver will display "dddd" when its loading
      9. do not turn off the box or pc at this time
      10. wait for pc to display download successful
      11. then the receiver will switch itself on when downloading is finished
      if that fails try this
      switch box off/on ..press start and see if it helps...try switching box off..press start...switch box back on...keep trying more than once.
      if you have not got a pc wth xp on it try running the loader softare in xp compatability mode
