DM800 broken tuner?
  • tweak2
    • Feb 2012
    • 7
    DM800 broken tuner?
    Hello, 2 days ago i decided to buy a clone 800-C (cable tuner) (500-C clones worked fine) first problem came up, it was not finding any channels.. i looked on internet and tried everything, it looks like the tuner is broken or the software is not working with it?
    when i install newest gemini and do a scan, its not finding anything, when i try 1 transponder then it works for the channels on it. but a full scan on 1000khz is not working..
    when i place bouquets on it, its working! it tells me 82% signal strength on the channels. but a full scan should work? (i always worked with cables.xml on 500C)
    so i tried to install newest Pli, and placed the bouquets and it tells me 33db on channels.. (to low so wont see a thing) and on pli all scans dont work..
    can someone tell me is this dreambox broken or?
  • tweak2
    • Feb 2012
    • 7
    Hmm, when i go to default satlist, it says there is no default on my firmware.. maybe its possible to get a cables.xml there? i hope someone can help.
    • mtv1
      The Stig PT
      • 4413
      http://www.google.ie/url?sa=t&rct=j&...QecHAfnesMZXCg bit of looking around mate but brutforce seems to be the way good luck
      • lincsat
        • 1228
        If you enter the default transponder for your area and select a single transponder scan with Network search ON, does that work?
        • tweak2
          • Feb 2012
          • 7
          hmm, i got most channels working with my cables.xml its possible to upload it to /var/etc/tuxbox and go to tuner setup and select it.. but its not finding everything and im sure the transponders/freqs are in the file.. maybe the signal strength is not oke? (cant be the cable) its 0.5m from the green cable.
          Maybe indeed bad tuner?
          • tweak2
            • Feb 2012
            • 7
            i dont know the default transponder.. i got a list with all the transponders etc but it doesnt say the default. (thats where my cables.xml is based on)
            • tweak2
              • Feb 2012
              • 7
              Tuner has been replaced, and same problem.. so i looked for other cables.xml (maybe mine is not good..) and now it found 170 channels.. (still not enough) very strangeee but more then before
              • tweak2
                • Feb 2012
                • 7
                Oke , i got it! its in the tuner config.. if others have the problem to.. solution
                place correct cables.xml in /var/etc/tuxbox
                go to tuner setup
                choose the searchmethode -> Provider
                Search on Provider -> your region (from the cables.xml)
                press ok
                now go to search MANUAL (NOT AUTO)
                choose Complete
                Network search NO
                and ok
                now i got
                Edit: so it was not MY cables.xml all it was is the Network search that needs to be on NO
                • tweak2
                  • Feb 2012
                  • 7
                  it is not 100% fixed i can find max 302 channels, and there are more. its very strange, when i create a empty cables.xml with only 1 transponder (missing channels) and i give the command to search, it says nothing found.. (its only on a few transponders) when i place channel list on it that someone created, the channels on that transponder are working fine with 80% SNR.. is this a signal problem or software/tuner ? i hope someone can give me a answer
