2 Way Splitter
  • shakespeare
    2 Way Splitter
    Hi,
    I have just bought a splitter and put it on my V broadband and use one lead to watch the TV and other to the modem. Unfortunately when i do that the modem doesn't work properly and hence i cannot browse the net,the tv works fine. But when i take the lead out of the splitter and directly connect to modem, the internet works... it does say Power Pass o the splitter.Also got 5-2400 MHz. I also bought a splitter without power pass and no joy, the same.can any one help please?
  • dank76
    • 745
    might be a faulty splitter mate also double check all leads
    • peternorton60
      • 12
      Does Work
      What you done is correct, it does work, reasons for no signal.
      A. Faulty splitter.
      B. Faulty workmanship, check all terminations with a meter.
      C. Faulty modem / router, whatever connects ( borrow a friends modem to try, this way you can rule out your is faulty)
      • melloned
        • 1215
        My brother had the identical prob Mate , a duff (cheap) splitter .
        Once changed , his broadband was fine , and he feeds 2 cable boxes off his tv feed , no probs .
