locked card
  • fatlad
    • 143
    locked card
    hi folks
    been given a sammy 2110c box with a paired N** card but the card is locked is there any way to unlock the card, if not do i bin it and use a funcard.
  • bugaloo41
    • 1598
    almost certainly require to buy an unlooper and for one card it aint worth it. use it to scrape the car. i assume you know the bk and ird and if thats the case just use your fun.
    • jim56
      • 94
      if you don't know the b/k then take very good care of the card and hope it's genuinely paired (i never throw anything away..).
      as said above you'd need to unloop the card so if you have the b/k then a fun is definitely the cheaper option.
      jim
      • fatlad
        • 143
        locked card
        thanks jim
        is it possible to program the paired if i can unlock it and how do i cut the talkback on a sammy 2110c
        cheers
        • bugaloo41
          • 1598
          mate if the card is locked personally I have found that romstudio is the best software to use to open the card to get the ird and bk. If you look at the bottom of your box you may actually see it written on that - very common.
          bit confused here. are you saying that you are using a box where the talkback is not cut? Your shout but it wouldnt be me. Cant post on here about modifying the box but google lets you know everything you are after.
          • jim56
            • 94
            The card is only paired if it contains the right b/k. It will show as paired in the e/m if the ird is right but that doesn't guarantee the b/k. You've not said if you actually have the b/k or if you need to get it from the card. If you need to get it from the card and the card was in the box when the service was disconnected the chances of a fake b/k are very high. If that was the case then you have a doorstop (I've got a few )
            As bugaloo41 says m8 - never mess until t/b is cut as the box wll still take any updates with it cut. Also never ever mess with a subbed box.
            jim
