if you live in the same province then yes that shhould be no problem - he should be able to view the same channels and will also get the same channel setup you have....
why does everybody flash when they lose channels.at most factory reset 0000 to delete,power off at back for 30secs/on autoscan ur provider with splitters removed ,and emu to on,exit out.
