nope that didnt work, also i recopied a services file which has the channel in it and reloadedsettings - and still it shows as "service could not be found"
still get the EPG not that its any use at the moment
hashley delete the channel first then do a rescan and it will pick it up. confirm its still showing.
copying an old services file over is unlikely to pick up the channel if its the same one you have on your box. it may have altered frequency. have you tried a bruteforce scan?
