my box freezing any one can help me please ddigital plus
  • good_121_good
    • 9
    hi i want help please my box ddigital plus work two minute thgen freezing and i have to switch off then to work again two minute and freezing help please
  • bugaloo41
    • 1598
    i take it you have the latest software installed (its 5 months old mind)? it could be that vm are doing work in your area. you could try a rescan to see if some channels have moved transponder and finally if all else fails could try a booster.
    • good_121_good
      • 9
      thank you for your replay but i download the sotware again and make factory reset and rescan but same problem about the booster where can find it thank you again
      • bugaloo41
        • 1598
        try this one if it doesnt make any difference you can get return it and get a refund
        Buy 1 Way Plug-In Aerial Booster. at Argos.co.uk - Your Online Shop for .
        • mark015
          • 254
          i use that one it works well for me had it for about 18 months now.no problems with it ...
          • welshbhoy
            • 25
            I need a booster I think cos some channels freeze on my boxes. I can't get Setanta either on two of them. If I was to get this would it work on the pace boxes?
            By the way, I have a splitter, 4 way but only use three ports, 1 for BB and 2 for TV signal. Any cheap way of improving the signal from that?
