Starview 4 Super USB problem.... Please HELP!
  • chetm
    • 5
    Hello Everyone,
    Ok, i have the starview 4 box, had in for around a month or so now... and basically its just turns off after maybe 20minutes of watching it and then when i turn it back on it will turn of in within a minute or two. This has been happening for the past few days, and today it dosent even start!! im getting a response from the box, and there is numbers which are appearing on the display of the box when i try and turn it on eg.0002, 0008 and then it will just cut out and have ---- going through the screen and then 0002, 0008, ---- etc... I would be very grateful if someone could advise me on what i could possibly do to fix this problem
    Thank You Very Much in advance
  • gazza2008
    Originally posted by chetm
    Hello Everyone,
    hello m8
    If its coeing on and u can see channels on the front....Then i would try a reflash of ya box.... that will take it back to factory settings.....
    see how u go with that......if that dont work come bak..
    • chetm
      • 5
      Hello Gazza.
      Thanks for replying
      We are actually unable to actually change anything on the box.... nothing is appearing on the screen either... as i said it my orignal post it just shows 0002,0008,---- on the screen these three images repeating one after another once i turn the box on.
      Thank You.
      Is there no way i can restore it to default factory settings, or maybe even updating the firmware?
      • trevor1969
        • 361
        where did you buy it from
        • chetm
          • 5
          someone near my house... found the item on ebay and contacted the seller...i wanted to know if there is any way i could connected it to my computer and maybe change the firmware and see if that works? but i dont see how i can connect it to my laptop...a null cable has been suggested but i dont see were i can connect this cable on the back of the box?:S really annoyed as ive only had it for around a month.
          • smoggy
            • Apr 2009
            • 12771
            check out here http://www.digital-kaos.co.uk/forums...12-08-a-19539/
            • chetm
              • 5
              ok thank you to everyone that tried to help sovle the issue. I opened the box to see if anything had broken, i found that there was a cable not connected, reconnected it and it works fine again.
              Thank You again
              • kr1s77
                • Mar 2009
                • 161
                well done mate, glad u sorted it
