2nd hand digivox?
  • utdman
    • 183
    2nd hand digivox?
    picked up a 2nd hand digivox from the carboot @ the weekend but since ive never used one before i cant figure out what model it is.
    the main shell is silver with a 'half black' strip @ the front of the receiver.
    it says digivox on the right hand side of the front panel.
    hooked it up with cable line but get no picture whatsoever even though the channels have been tuned in by previous owner.
    ive tried auto scan but still cant pick up any channels???
    went into sys info and got the following info:
    Model-digivox
    S/W Version-V03-2.8000BK
    Boot ver-01
    Date-1.Jan.2007
  • tubs
    • 420
    digvox
    Hi yes you have a digvox t it is a very good box but you will need to put latest firmware on for it to work get back to me if you need help
    • cactikid
      • 12017
      Model-digivox
      Boot ver-01
      Date-1.Jan.2007
      silver digivox firmware is v4300 latest,as long as it does not say digivox t which is for irl only.
      coaxial into cable input,factory reset 0000 to delete autoscan ur provider and emu to on.menu-system info-ok1004-emu to on.u might have to change provider id might be different than what was on it.
      • cactikid
        • 12017
        both boxes are identical but it would have to have digivox t on front,firmware is also wrong,and in uk location also wrong as a t box can only be used in irl.
