Silver Digivox
  • yendor1
    • Jun 2009
    • 8
    Silver Digivox
    Hi All, I have a silver digivox and just recently I lost all channels. I have tried flashing new firmware e.t.c. with no joy. I had a mate of mine have a look and he said that all silver digivox,s are now useless. I'm in the midlands and would like to ask if anyone else is having trouble and if the box as my mate has said is now useless.
    Thanks in advance.
  • gazza2008
    Thanks in advance.
    after you flashed it did u do a factory reset then scan & turned the emu on m8
    • mtv1
      The Stig PT
      • 4413
      did you press1007 or1004 not sure which and make sure keycode is on
      • yendor1
        • Jun 2009
        • 8
        tried both. no good
        • mtv1
          The Stig PT
          • 4413
          go to system info press ok then try 1004
          • gazza2008
            stig its 1004 m8
            • cactikid
              • 12017
              Thanks in advance.
              find out what was flashed/firmware as it could be wrong and dont
              mind gazza no 6 .
              • yendor1
                • Jun 2009
                • 8
                any chance you can let me know what firmware i should be using. I'm thinking of flashing it again and then following your previous advise. thanks for the replies all.
                • cactikid
                  • 12017
                  if ur in uk u can flash it with v4300,do a factory reset first,flash box,then autoscan and emu to on.
                  if ur in irl box more or less useless as nearly all channels have moved to n2 encryption= no fix.
