Sony Tv
  • shaney
    • 40
    Sony Tv
    Hi i recently changed from dw 2 image to dk image latest and lost sont tv any ideas or should i go back to old image thanks everything else is ok dreambox 500c
  • on_the_jazz
    • 557
    Have you tried deleting it from the list and doing a rescan?
    • shaney
      • 40
      it does,nt appear on the list checked every single channel not listed
      • on_the_jazz
        • 557
        Which area are you in? I think you'll need someone to give you their services file, or just the frequency so you can manually add it.
        Also might be worth connecting your box directly to the line without any splitter to see if a stronger signal helps with picking it up.
        • shaney
          • 40
          Thanks mate tried direct connection am in sw london if that helps
          • on_the_jazz
            • 557
            I'm nowhere near there and the only services I could see in the downloads section are for east london. Hopefully someone on here will send you theirs but if not it maybe worth trying a signal booster (that is if your signal is a bit on the low side).
            • dldl17273
              • Aug 2009
              • 11
              Hi can any one tell me if i can use a PCMCIA
              card on my sony tv to get v.m chanels i can get fta but like to got ppv so i can put my dreambox in the beroom thaks
              • peggybobby
                • Sep 2009
                • 33
                hi
                dldl17273
                you need a cam m8
                and to know the boxkey of the cam
                am sure maybe somewhere on the board this might be available
                i am new here but have not had time to go through the sections of stuff
                i know.......
                if you get the right info...and if ...you will ne some extra programs.....like swapbinhex,toxic7...and a card reader..to name but a few
                good luck
                rgrds
                peggybobby
                • Swiftie
                  • 141
                  Have a look on here, http://www.digital-kaos.co.uk/forums...equired-29277/
                  E Pluribus Unum
                  From the one to whom much has been entrusted, even more will be demanded!
                  If you have received help from this post, press the "THANKS" button to show your appreciation.
