Help Digivox XL
  • cb-lfc
    • Jun 2009
    • 17
    Help Digivox XL
    Hi i just got one of these today set it up and i havent got all the channels can anyone help thanks
  • cloudnineuk54
    • 530
    hi mate,have you enabled emu,,menu,system info,press ok, then type in 1004,turn emu on press,ok on set defaullt k*y,exit out to tv,let it update on sly sp. 1
    Last edited by cloudnineuk54; 1 July, 2009, 15:07. Reason: missed a instruction out
    • cb-lfc
      • Jun 2009
      • 17
      hi mate when i press ok on the system info it just flashes
      • cloudnineuk54
        • 530
        then its not right mate try a factory reset first and rescan it and try again,if not id reflash it.i assume youve put new firmware on it
        • cloudnineuk54
          • 530
          oh missed out system ok "then type in 1004" then turn emu on
          • cb-lfc
            • Jun 2009
            • 17
            no mate havent put new firmware on it how do you do that i am new to all this
            • cloudnineuk54
              • 530
              well i suggest you read all the guides on that box,its a easy box to flash,but basically you need the latest image,and downloader 10 to flash the box. and if using a usb to null adapter pay paticular attention to the com port set up,and make sure the driver for the adapter is installed.and have box powered of hit download then power box back up,factory reset before you scan it
