Sony TV with Dragon or Diablo Cam
  • skanker
    Have any of your guys got experience of getting the Sony TV working with these CAMS? I cannot get my TV to even recognise the Dragon CAM, I hope my TV is not faulty.
  • khenryashley
    • 783
    Read through this thread you might pick up some info
    • mintyfresh
      I can confirm that the T-Rex/Dragon cams do not work in these TVs. I have tried one with various flashes and all it seems to do it cause the TV to glitch, nothing wwill clear.
      However, Diablo cams do work. It will work with either a card or in emu mode without a card (although no AU when in emu mode). The only problem with the diablo cam is i can't get it to clear BBC HD.
      • mgb17
        • 37
        Did you try to enable only ca-id 1800 via the software editor for the T-Rex/Dragon cam's?
        Beside that the ci-slot at the sony x3000, x3500 and W3000 series has an design flaw and there are problems with the majority of cam's.
        • khenryashley
          • 783
          Joker cam with funcard works ok. (0.79 firmware)
          • mgb17
            • 37
            That is a nice information but says not much without mention the model number of the sony.
            • khenryashley
              • 783
              I believe this works on any Sony model that has a internal cable tuner (v , w, x and z models)
              • mintyfresh
                I tried manually edited setting so only caid 1800 and nagra were enabled - still no luck. In fact, i could not even access the cam menu on the TV with the T-Rex/Dragon. BTW all my tests have been carried out on a V4000 model
                • rajdhani
                  dragon cam will not work on it as i have already tried it.
                  Just get a joker cam
                  • mgb17
                    • 37
                    A dragon should working it you enable only caid 1800 and don't try to access the cam menu.
                    You have to flash the cam via a other device.
                    • Manc-Red
                      • 24
                      Hi guys - have a diablo in my sony bravia & the tv is reading the diablo no probs - is there a way via either a card or file that I can open Nag 2 in dublin with this...
                      Cheers in advance
                      * Just noticed in another thread that my diablo can be updated for viewing with a key bin, if anybody has this key bin please pm them to me if its not 2 much trouble - thanks *
                      • square88
                        • 55
                        Mgb17 were did u hear this from?
                        I have a 40W3000 with joker 0.79 and Funcard decrypts all channels sound but picture is all scambled.
                        Same cam and card in my brothers 40W4000 and everything clears even BBC HD
                        Sq
