Hi please be patient if i posted this in the wrong section and if the question seem silly....well i have downloaded the bbc iplayer and a series to watch but i have only a week to watch after open the file the first time.....Is there any way to take away this limitation so I can burn the all lot in a dvd and keep the disc?Many thanks
bbc iplayer question
iPlayer Recording
Watch the iplayer recording via the legit CableTV box. Connect the CableTV box to a dvd or video recorder using a macrovision scart lead. I've done this using a SonyDVDR with Hard Drive and this solution works fine.Hi please be patient if i posted this in the wrong section and if the question seem silly....well i have downloaded the bbc iplayer and a series to watch but i have only a week to watch after open the file the first time.....Is there any way to take away this limitation so I can burn the all lot in a dvd and keep the disc?Many thanks
As far as removing the encryption from the file on your PC, well that's something I haven't tried, but similarly, if you have your PC hooked up to your TV & Media system and can watch it on that, then again, try using a macrovision scart lead between the source and the recorder but as I said, I have not tried this myself.
