Splitting tv cable for multiroom
  • happy_highlander
    • Aug 2010
    • 3535
    What is the best splitter to use on vermin cable to run it to another room.
    Will any do or is there one that performs better than others
  • rhinoranger
    • Aug 2009
    • 42
    i think the cable splitters are more or less the same but if you split the signal you might need a cable signal amplifier/booster,i use a konig signal amplifier,the signal might be ok when its split you will need to test, i have put a couple of links on so you can have a look -:
    (1) Search for virgin splitter kenable for HDMI Optical TOS Network Ethernet RJ45 Scart Audio Phono Jack USB Firewire 800 ADSL Cable Leads
    (2) https://www.google.co.uk/search?q=ko...49.gWf5THGMwXc
    • digicon
      • 8261
      HH if you have a splitter in the frequency range of 5-1000mhz is also fine as most lose -3db per port check to see if you have any attenuators on your line at the moment possibly at the rear of the box or the rear of a modem and remove as necessary as the splitter will do the job of the attenuator
      • happy_highlander
        • Aug 2010
        • 3535
        Think there are atenuator thingys at the not super hub and the box aid something about it being too strong a signal
        • kaisar1
          • Aug 2009
          • 462
          hi all, i got virmin broadband. 1 cable, how many twin tuner boxes + internet can i run of one incoming cable???
          i need twin tuner in 2 living rooms and single tuner in bedroom.
          • happy_highlander
            • Aug 2010
            • 3535
            Well if you look at digicons post you will lose -3db per port added and in my house the attenuators were 6db so if you want to add another 4 ports you will need to use a 6 way splitter losing you -18db 3 times more than 1 attenuator so if you look further up the thread there is a link to a booster which you will probably need
            • kaisar1
              • Aug 2009
              • 462
              i got one cable coming into the house which is connected to 5-2400mhz splitter, a cable going into router which seem fine, another cable going into q5 hd box which is glitching every 5 sec, signal quality drops from 100db to 10db and keeps fluctuating between the two.
              how can i sort this signal issue???? any help people.
              if i connect incoming cable directly into q5 hd receiver, quality is perfect.
              • digicon
                • 8261
                Sounds like a weak tuner in the Q5 receiver which can only be cured by boosting the signal:
                http://www.ebay.co.uk/itm/Cable-TV-Broadband-Amplifier-Signal-Booster-with-Active-Return-for-Virgin-CATV-/230854379790?pt=UK_Sound_Vision_Other&hash=item35bffe490e
                • kaisar1
                  • Aug 2009
                  • 462
                  thanks, once this is connected how many boxes can i feed of this???????
                  the cable incoming into the house connects to the above and then the cable that connects to the router. what is that???
                  could i get virmin tivo tv installed and cancel within 7 days, excuse i could use is that i lost my job?
                  no doubt i would have to pay ?50 installation charge, in return i would still have bb and 3 feeds which tivo box would have left.
                  • digicon
                    • 8261
                    Leave the isolator in place and then connect a small piece of cable from the isolator to the booster and take the feeds from the booster with the use of a 5-1000mhz splitter
                    • kaisar1
                      • Aug 2009
                      • 462
                      problem was the splitter. bougth a new 2 way splitter from local electronic shop RF potts - highly recommend this place, babington lane, derby. Always bust with customers.
