combo boxes
  • iain66
    • Dec 2010
    • 52
    combo boxes
    Does any one know if on a E2 combo box sat/cab do you have to install both a sat and cab channel list
  • loncell
    • 625
    get a miraclebox premium mini HD ?159 , everythings done via download through the VIX server, piece of pish
    • cactikid
      • 12017
      you can have a combo box and work on one side or both,its your choice of what way you will go.
      • happy_highlander
        • 3535
        you can also combine both sat and cable lists to give you a set of favorites that include all the cable hd with the sat sd. The switching time between tuners is negligable (well it is on the quad plus anyway)
        • polosolo
          • Jan 2013
          • 9
          Hello guy`s I have a vu ultimo and was thinking of buying a cable tv tuner for the box ..Now I belive I am able to use this as a combo box once installed
          Sat & cable(vermin) I have the latest appollo 13 version on this box atm , does this image support cable ? or will I have to go with BH or something similar.?
          I am sure I will have more questions soon regarding the transitions , so please bear with me.
          Thank you all for your time and help.
          Best Regards
          • happy_highlander
            • 3535
            As far as I'm aware all the images support cable tuners if the box is capable of using one. If it is vix apollo you are using then autobouquets can also be used for the cable side without any messing
            • WOODWARD395
              • Apr 2010
              • 628
              You mentioned this earlier to me happy_highlander do you have a link for the program so I can give it a try.
              I thought Autoboquets was just for sat and you have to use autoboquet maker for cable.
              Education is not the learning of facts, But the training of the mind to think
              So hit the thanks button if I have enlightened you.
              • WOODWARD395
                • Apr 2010
                • 628
                Best Regards
                vix image supports cable and sat but use vix ver 14 as I had tuner issues with 13.
                • happy_highlander
                  • 3535
                  Dbe will be in the downloads section. Now I'm not sure how the cable lists work. By that I mean not sure if they will work in regions other than the one they were scanned in but it would be nice if you could upload this http://www.digital-kaos.co.uk/forums....php?p=2325367 to your box using dbe and let us know if it's just the regional channels that need changed same as sat. You may need to add the cables.xml manually as dbe only upload the satellite.xml. You put both cable and sat xml in same place which if memory serves me correctly is etc/tuxbox
                  Edit: correct channel list in the link now
                  • WOODWARD395
                    • Apr 2010
                    • 628
                    happy_highlander thanks for that m8 appreciated.
                    • happy_highlander
                      • 3535
                      Oops linked to wrong channel list my bad sorry here's the combo one http://www.digital-kaos.co.uk/forums....php?p=2325367 there are a couple of errors still in it. Namely itv 4 hd is still from sat in the hybrid entertainment so doesn't work and itv hd is missing from the vm cable entertainment. I have fixed them but lists will be uploaded once all other sats have been updated in a week or so
                      • WOODWARD395
                        • Apr 2010
                        • 628
                        thanks sorted m8 have a look tomorrow.
