  • Dreamer786
    • Oct 2013
    • 55
    #16
    by connecting a splitter does it automatically lose some signal or not
    • digicon
      • 8261
      #17
      typically -3db per output
      • Dreamer786
        • Oct 2013
        • 55
        #18
        That is not a lot is it. If my signal is strong and i get a good splitter should it be okay? Dont want it to lose. Can u link me to a high qual splitter please digicon help much apprecieted
        • digicon
          • 8261
          #19
          All splitters even a Good quality one like Triax lose at least -3db per output dont worry about it give the splitter a go first and then if you have problems then look at a booster of some sort
          • Dreamer786
            • Oct 2013
            • 55
            #20
            I will do the second connection from the splitter wont be connected for a while so it shouldn't give me a problem anyway should it. And thank you that's what I will do hopefully all should be okay and well
            • Hadron
              • Nov 2012
              • 2102
              #21
              In my Dbox2 days I used this splitter from Maplin:-
              2 Way F Plug Aerial Splitter | Maplin
              I then saw the same ones in a ? shop which worked just as well!
