Amino Mini HD TC/2 Picture Quality Issue
  • jm7162
    • Apr 2013
    • 13
    So regardless of the channel I'm watching there seems to be a lot of blocky pixelation. No really sure what the proper name of the problem would be but it's similar to when you get bad weather on satellite.
    I have no issue's when using a Vermin box.
    Anyone got any ideas?
  • mark8393
    • 2305
    Dodgy tuner maybe, or signal maybe too strong or weak for that box
    Sent from my HTC One_M8 using Tapatalk
    I
    • jm7162
      • Apr 2013
      • 13
      I can only think thats it too strong for the little box, i have another 2 on order so i'll find out tomorrow i guess. It's a shame reslly because at ?50 from a UK supplier they're a bargain
      • iain66
        • Dec 2010
        • 52
        if you put a splitter on would that not reduce the signal by about -3db some one with more knowledge may know if it would work
        • jm7162
          • Apr 2013
          • 13
          Yes, its already on a splitter. Are you saying to use one to reduce the signal strength or tha
          t it needs to be increased?
          My signal is 99% quality 90%
          • cactikid
            • 12017
            as with the early kv850 that had a signal level issue and people were told to use a variable attenuator to decrease signal.
            • jm7162
              • Apr 2013
              • 13
              For under ?4 a unit its worth a try, i'll wait for my two new boxes to arrive tomorrow hopefully the box i have now is faulty. Quite a headache this... Im also not getting failed scans and missing channels, every scan returns a different number.
              Very annoying!!
              • loncell
                • 625
                I'd like to bet you've bruteforced scanned then your viewing a channel were there's probably 4 channels named the same. Look at the frequency details of that particular channel and you might find it something like this 405.975 rather than something like 406.000 which means it's slightly off.
                If it is then delete that channel or scan with your correct freq. The freqs that's knockin about are sometimes wrong. Get the correct freq from a subbed box . I had this problem and it wouldn't find a thing off the freq that's mentioned in forums, , ,when I checked off a tivo it was complete different.
                • jm7162
                  • Apr 2013
                  • 13
                  Thanks for the advice, i did about 4 scans one after the other and have a couple dupes but so far so good. I'll have to test on some more channels.
                  is there a list anywhere which has the correct frequencies?
                  do channels change frequencies like they do on sat?
                  • loncell
                    • 625
                    get the freq off a subbed then your 100% sure it reet. if you've not get it off a friend or ask on here for the correct one for your area. mine use to be 530.000 or something. When I scanned I got nothing so I looked in my tivo and it was 595.000
                    oh and delete all channels before you scan with the correct freq or you will be back in the boat
                    • cactikid
                      • 12017
                      i do believe there is a tp and netid list around
                      if yours differ please add to that thread please.
                      • loncell
                        • 625
                        Wigan says 531.000 thats wrong it's now 595.000 if you search on 531.000 you get nothing netid and QAM are the same, I'm not sure what others are right and wrong that's why I said check on a subbed box.
                        • jm7162
                          • Apr 2013
                          • 13
                          Do you know how i can get it from a
                          Cisco 4585DVB. ?
                          • loncell
                            • 625
                            Cisco 4585DVB. ?
                            Sorry can't help you there bud, try the one in the link netid and freqs , if that only shows a few channels or none then it's changed. Just say roughly were you live someone might be able to help you on here.
                            • jm7162
                              • Apr 2013
                              • 13
                              Harrow, is it worth making a new thread?
