VM London channel listing bouquet and upto date
  • square88
    • 55
    Hi guys anyone have a full VM London channel listing bouquet and upto date cable.xml they can up load or send me?
    I cant seem to get many channels including BBC one HD missing and a lot more.
  • andy91
    • Aug 2010
    • 3583
    Always better doing it yourself as you can only get a channel list for your area with cable but you need to tell people what box you have.
    Andy.
    • square88
      • 55
      Andy.
      Hi thanks Andy
      Im using a DM8000 with an additional cable tuner, only manage to scan 283 channels missing a lot of channels including bbcHD and Sky sports 5 most of the kids channels amongst others.
      Have tried auto scan and single transponder scan.
      Any help appreciated.
      • andy91
        • Aug 2010
        • 3583
        Hi thanks Andy
        Have you added cable xml into etc/tuxbox?
        Andy
        • square88
          • 55
          Andy
          Yes i have
          If you have a more upto date one can I have it please.
          • andy91
            • Aug 2010
            • 3583
            Cable xml file
            Think this is the one I used.
            I found when I added my additional s/r for my location I was worse off.
            I just did and auto scan and found 586 channels then used auto bouquets which needs setting up properly for cable.
            Have to scan on a working channel but on the image your using I'm guessing you will have to do a lot more than that to get auto bouquets to work.
            You will need dvb snoop installed with auto bouquets and all Attributes Chmod will need to be changed to 755.
            Andy
            • square88
              • 55
              Andy
              Do I select *****under tuner config?
              • andy91
                • Aug 2010
                • 3583
                All I did was add the cable xml enable the tuner and add net id and scan. You will get 90% of failed transponders but let it run and see what you get.
                If its still the same its worth adding your addition s/r foor your area if you know which one is yours.
                Andy
                • square88
                  • 55
                  Andy
                  Did that but only pulled 80 channels.
                  • andy91
                    • Aug 2010
                    • 3583
                    Did you add adittional s/r?
                    Mine is 6887 and 6892 but all areas are different,there is a net id thread in the cable section somewhere.
                    Other option is to get auto bouquets to work but run it off a working channel.
                    Think the AAF or ATV Open image has built in bouquet maker that might be worth a try.
                    What image you using? I know a lad with a Dreambox 8000 will email him and see if he has a back up image.
                    Andy
                    • square88
                      • 55
                      Andy
                      Yes have tried 6887 and 6952 which is my S/R (London Hackney)
                      I'm using a DM8000 ferrari sim
                      with openblackhole image.
                      Thanks m8
                      • andy91
                        • Aug 2010
                        • 3583
                        My mate has original dm8000 sim2 so can't help you there. Best bet would to get auto bouquets to work.
                        What net id are you entering?
                        Has to be entered in correctly.
                        Andy.
                        • square88
                          • 55
                          Andy.
                          Using these
                          Hackney - N.London TW, 40985 515000 6952
                          Input via tuner config then auto tune because single transponder tuner does not pick up anything.
                          Oh auto bouquets only scan for sat channels cant seem to see option for cable channels.
                          Cheers.
                          • andy91
                            • Aug 2010
                            • 3583
                            Have sent you a pm have a read of the thread from another place.
                            Andy
                            • square88
                              • 55
                              Thanks mate will read
