what firmware is on box,check downloads for latest,need a pc with serial port rs232 and a null modem cable to do it right.sounds like your not scanning from direct feed or wrong provider.
ok you are on latest firmware,are you scanning from direct feed,if you have a providers box you can get the info off it like provider and correct net.maybe you have a low signal?
