euro vox max v software update
  • creative
    • Aug 2009
    Hi I`m a newbie ,so could some kind person point me in the right direction on where to get the lastest euro vox max v software /firmware updates as all I`m getting at the moment is SEARCHING FOR NEW CODES.
    Thanks to anyone who can help.
  • smoggy
    • Apr 2009
    • 12771
    Hi and welcome to DK
    you can get latest firmware here Digital Kaos - Downloads - Eurovox Max V UFL Firmware (30/11/08)
    • clarkybhoy
      • Aug 2009
      • 14
      If you go into the menu then configuration, select clear data then reset factory default then select 2nd option 6887 (glasgow area ...anyway) Then press OK. You then get a frequency range setting option that appears on the screen, I just moved through all the options to the last one which is titled "step" and the pressed OK without changing any of the details. An automatic scan will begin with the screen going black and the it will search for transponders this can take upto 15 mins. Once complete you should have your channels back again, if not try again, it took me 4 goes before I got everything back again. Hope this helps GOOD LUCK !
