Hi i.m new to this. Box went down and someone has said need new codes for 5a01 telewest provider. can anyone help with codes - aug 09 thanks
5A01 telewest codes
This topic is closed.
I don't think if keys can be posted in public forums so easiest fix is to do this.
Download the keymaster from here -> http://www.digital-kaos.co.uk/forums...-v1-2-a-15751/
Extract it from the archive and run the KeyMaster.exe
If it doesn't run then make sure you have .NET Framework installed into your system. Which you can get from here -> http://download.microsoft.com/downlo...dotnetfx35.exe
That way at least next keyroll you can get your keys by just running the KeyMaster again.E Pluribus Unum
From the one to whom much has been entrusted, even more will be demanded!
If you have received help from this post, press the "THANKS" button to show your appreciation.Comment
QUOTE=jessamfay;455519]"what is telewest code for today?[/QUOTE]
Maybe read the 2nd and 3rd posts on this thread!
Whatever!!Comment
there aint been any new codes since october, update the firmware on the boxsupport mountain resue
the keys auto update, but there wont be any because vm are rolling out a new encryption called nagravision 3 which is a box killersupport mountain resue
