Cable Movie Problems!
  • m4tty_g
    • Mar 2009
    • 6
    Hi there!
    I currently have all the movie channals but they all have audio description, and its now doing my head in! ive tried to re-scann on a number of occassions with no joy!
    Does any one know how to fix this issues????
    Cheers.
  • badapple
    • 2041
    Originally posted by m4tty_g
    Hi there!
    Cheers.
    Sorry! wrong section
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
    • HGV_DIAG
      • Aug 2009
      • 192
      new commando 11.3 stops all this from happening. Give it a try
      • mickydibble
        • 2166
        may depend on what image but try this mate:
        Press the dbox button.
        Select "settings menu".
        Select "key binding setup".
        Select "TV/Radio mode".
        Select "set to none".
        Go back through the menu's until you can press the red button to save your settings.
        You should now find that channels which display the green key option under the EPG info banner, will allow you to change audio channels
        if your image does not display this option then you could install new img like com11.3 which as option in settings to permanently disable audio description
        • tubs
          • 420
          yes just go to to aduio and change your english over that should do it
          • biggidave
            • Sep 2009
            • 11
            Having same problems when it was working.
