Newbie needs help with Digivox T
  • chale
    • Sep 2009
    • 8
    Hi all,
    I am based in the sticks of County Clare. and i am a total novice to this site and would like help with my digivox -T - v03-2.0000T.
    The ariel is facing limerick .
    For 6 months my signal was great but recently i tend to get scrambled or bad signal on several stations.
    Is this due to leaves on the surrounding trees which were not there when chorus set me up
    is there another mast i could turn ariel to
    pls help
  • red devil
    • Oct 2008
    • 690
    Originally posted by chale
    Hi all,
    pls help
    you must be on the east of the county so your aerial is either hittin the
    limerick mast or keeper hill not really another mast unless you can hit the kerry one but you
    would need to change the downconverter
    but more than likely the installer went with the best signal so not really an option
    with mmds its possible the trees will ~~~~ up the signal
    if you still have the subbed sagem box connect it up and go to menu/information/signal information
    and check the sig strength on channels like virgin and playboy
    • chale
      • Sep 2009
      • 8
      did this on several channels
      signal strength 64
      quality medium
      e/n 16db
      what next ????
      • red devil
        • Oct 2008
        • 690
        signal strength 64
        quality medium
        e/n 16db
        what next ????
        ok...you have def got a problem with your signal....medium/16db is no good
        you should have at least 21db but ive seen em work on 19db as well
        what next....check all connections, change downconverter, put aerial on a higher pole
        cut down trees ......or if you are still payin a subscription (and u should be )
        give ch0rus a ring
        • chale
          • Sep 2009
          • 8
          thanks will give Chorus a call before the leaves fall of
