Lost channels?? Nag3 or what?
  • OliverTwistd
    • Sep 2009
    • 6
    Hey guys
    My very first post here...havent really been into the scene for a while since I had a working setup which worked for me and hadnt needed to tweak it at all although it may be considered a bit primitive for some of you!
    I use a PCI cablestar card in a pc with ProgDVB and a few other bits of s/ware. Thing is I've lost 90% of channels since Wednesday night. The stream still shows but nothing happening when channel is clicked on. Even lists the channels when I scan each frequency, just arent viewable. Everything was working fine before. As is usually the case, I've been searching online but since I dont have a standalone box like a lot of you guys on here it seems I'm alone in finding a fix.
    I dont know if this has any bearing but was on virmin portal the day before it happened and tried to register for a speed upgrade for broadband but that crashed and said I needed to ring them up...which I havent had a chance to do yet. Could that have triggered something...I dont see how it could really but then I dont know enough about this. Just using a splitter on the main feed which goes to the PC.
    I do have a regular sub with them for TV,fone and bband.
    There was a similar thread where Leeds had lost channels and that isnt a million miles from me (I'm in ex CW area,5C01) but that was down to an outage at virmins end.
    Does anybody know what this is? Checked a certain software prog which shows i have the correct keys (yes I still manually update!)
    Only getting a few FTA channs at the moment. Can anyone here shed any light on this??
  • Swiftie
    • 141
    As long as you know 100% certain you have the right keys and your EMU option for your PC Card is switched on then. I can suggest maybe a (restore to default option and trying a rescan) but remove the splitter when scanning and then place back if you get more luck.
    I lost some channels aswell this week. Even had a problem where Sky Premier, Gold and some others was being picked up but not sorted correctly for whatever reason.
    I just persevered since Monday as each time I scanned I kept losing certain channels not always the same by the way. Have just now (30mins ago) restored a Digivox and rescanned. Picking up 303 channels and everything is back to norm again.
    But hey I'm not in Leeds mind you.
    E Pluribus Unum
    From the one to whom much has been entrusted, even more will be demanded!
    If you have received help from this post, press the "THANKS" button to show your appreciation.
