cable xml
sorry for bad info it is comando 15.ib im using i have been playing around witha dbox as well and its that its using 12
just had email mate said hes got problem with server so lets hope this fixes it
cheers everybody for your inputComment
Really? Try again -
A month to the day since TC last released the updated 15.1b version. What's changed in this version? Two main things, plus shedloads of minor stuff... We got rumblings that if you ran AutoBouquets on most "ITV" based channels, then ABs would bomb out with a "No data found" message after a 2 minute time-out.Comment
Commando 12 wont scan till you update the settings
cables.xml
scan.config
but it will work when all this is done mines running now
but with H.D boxes at 70 notes its hardly worth the troubleIf your Happy with the Help push the Thanx button
PAUL
I gave one to the daughter to use in here bedroom I have tried everything and it's never finds bbc3 or channel 5 , it has to be the tuner I'm sure yours is the same
Sent from my iPad using Tapatalkany information provided is for educational/experimental purposes only.Comment
I have 2 boxes and the both are the same
maybe poor signal ??
im no tech minded but its like a transponders missing and all the channels on that transponder are not coming in could this be the case
or am i way off the mark as usual ?Comment
Autobouquets will find the frequency for all channels from the data in the stream. A poor signal would explain missing transponder(s), try removing all splitters and just connect the box to the incoming feed for the scan, even disconnect your modem to try.Comment
