channels all over the place
  • manmilk04
    • 8
    ive just set a H1 up with sucmnsee image all working but the channels are all over the place, there in alphabetical order at the minute and have no numbers, how can I get them in order or will it do it by its self when it auto updates the bouques? also in providers I have an extra folder saying H, is there a way to delete them all and do a rescan just on VM, cheers.
  • lincsat
    • 1228
    Does it not have Autobouquets maker? Set that with your region and search with that.
    • manmilk04
      • 8
      yes it has Autobouquets maker and I have set it to my area, I have al the channels but they are all over the place when I go to turn the tv over It starts with a load of bbc channels and then it goes alphabetical, you cant even type a number in for a channel because they don't have any, am baffled here.
        Have you tried pressing the blue button for the Favourites as it sounds like your in al 'All' list
        • manmilk04
          • 8
          yes I checked the favourites I have Virgin UK, entertainment, news, kids, audio description, local, red button, favourites tv, and last scanned, if i open virgin all channels i only get fta its when i open recently scanned that i can access all channels ie films and sport, but like i say they are all over the place, just don't know what ive done wrong, cheers.
            Go into ABM and try these settings
            Virgin UK
            -Virgin UK Area (your Net ID)
            -Virgin FTA Only no
            -Virgin generate main bouquet yes
            -Virgin generate sections bouquet yes
            -Virgin generate HD bouquet yes
            -Virign generate FTA bouquet no
            -Virgin generate FTA HD bouquet no
            -Virgin generate swap channels yes
            see how you go on with those settings
            • manmilk04
              • 8
              great stuff digicon that worked a treat thanks a lot all in order now, just when i use epg i can only see half the left hand side where it tells you what channel you are on how do i adjust this so i can see al the writing? thanks again... ok sorted that as well just moved it left a bit in settings, cheers.
              • lincsat
                • 1228
                Virgin UK
                -Virgin FTA Only no
                I prefer
                -Virgin generate main bouquet yes (HD Only)
                Then you get the channels with the correct provider numbering in the favourite groups.
                • Truth
                  • Jun 2013
                  • 174
                  Would the same apply to my Amiko Combi HD box?
                  I have started trawling through and adding channels to my favourites folders, if I do this now will it effect what I have already done?
                  Cheers
                  The Truth is out there ..........
                  • lincsat
                    • 1228
                    The Amiko Mini Combo isn't a Linux box, so no Autobouquets
                    • Truth
                      • Jun 2013
                      • 174
                      Thanks Lincsat. Is there anyway of organising them other than just setting up my favourites?
                      I am happy with the box overall , epg isn't very good at all and only shows the next program on , if any at all .
                      To record on it do I just have to but a memory stick ? Which is the best one to get ?
                      I should add I am running the box through Virgin and not satellite , which I think makes a difference with a lot of things on the box
                      • McFudge
                        • 35
                        Not tried this myself as i got rid off amiko box but worth a look
                        • Truth
                          • Jun 2013
                          • 174
                          Cheers mate. I have a new problem..... lost a load of terrestial channels within 24 hours of installation.....HD channels are fine though?????
                          • Truth
                            • Jun 2013
                            • 174
                            And it was down to the missis hoovering and loosening a cable on the back!
                            • McFudge
                              • 35
                              burst the bag !!.......................in the hoover
