hi could someone help me i have azbox and i have no idea where to put the roms and keys for cable
Hi Wullieb25
Download latest multicas then search for multicas edit 1.1 as this is the only version that can edit the k@y bin file.
Use nagra tab and choose 4 existing keys not used or any 4 you wish to.
4 you say?????? WHY????
It needs both lots for some strange reason make sur no # in front of multicas
RESET box flick up down on channel JOB DONE!!!!!!!!!!
If no work try mgcamd preferably red bulls and change the softcam k@ys
what do you mean by both lots of keys i put in the keys but still no luck what would i have to do with mgcamd so set it up m8
I mean if say in smellyVest there are 4 loads of keys same as N*L 2 set for your region and 2 for other with provider ID.
EXAMPLE ONLY
Name POVIder ID K@y no K@y no
Smellyvest 4501 00 BLAH BLAH BLAH
Smellyvest 4501 01 BLAH BLAH BLAH
Smellyvest 4601 00 BLAH BLAH BLAH
Smellyvest 4601 01 BLAH BLAH BLAH
THIS IS ONLY TEST it will not clear not even N3
enter with MultiCas edit Only and only 1.1 works
Stavross
im in 5a01 so i entered my two and the two for 5401 but still no luck am i doing this right m8 thanks in advance
Hi M8
Mgcamd redbulls only for Autoroll.
But if like me you have sat I use MultiCas and then use MultiCas Edit under nagra tab otherwise it won't work and make sure you use name' corect id and codes and reset multicas and maybe reset box
Latest software also a must with latest MultiCas also when sending key bin make sure you save each line you change by clicking the update if you try changing the keys on screen it won't work
thanks mate still working on it the now do you know where i could get the mgcamd redbull package complete then it would be just a case of installing it or ftp it
Our favorite SEARCH Engine G**gle
You will need to edit the softcam K@ys though already Pm'ed you M8 open with Word pad copy paste just the correct one's
