Auto bouquets time out lock on vermin
  • scottj130208
    • Apr 2011
    • 323
    Using vix auto bouquet maker have correct net id in whilst
    running scan on vermin it times out saying time out lock any ideas
    cable side is a nightmare sat is running fine I'm using a giga blue quad plus
  • plasterer
    • 1631
    Have you scanned your channels in .?
    auto bouqueter cant put them in order till you scanned them in
    PAUL
    • happy_highlander
      • Aug 2010
      • 3535
      That's not true. It scans them in fine straight after install
      • happy_highlander
        • Aug 2010
        • 3535
        Are you certain your using the correct area and have you set up c tuner and enabled it and do you have cables.xml file installed.
        • lincsat
          • 1228
          You do need the cable tuner correctly configured for DVB-C and in ABM, you must have your correct NetID set. If ABM is set for both Sat & Cable, then you must have a working Sat & Cable feed. There is no need to do a manual scan 1st or have a good cables.xml.
          The timeout for tuner lock means the box isn't seeing a signal on the set frequency which could be NetID, wrong tuner selected, no signal on cable feed.
          • plasterer
            • 1631
            My H2h wont sort bouquets till the channels are all acanned in for cable .............Paul
            PAUL
            • scottj130208
              • Apr 2011
              • 323
              Yes have net net id in same as my Zgemma which works fine also cable set to c in tuner configure and cable.xml also in the directory very weird it's like there is no signal tried without Zgemma plugged in makes no difference at a loss here
              • WOODWARD395
                • Apr 2010
                • 628
                make sure you have tuners configured correctly and your cables are connecting to your box that's the only way you can get tuner lock. if your not sure which cable is at fault disable each tuner in turn and you will find out which tuner is giving you the lock and ensure your tuners are seated correctly as that will give you the same. mine still scans if net id is incorrect and does not give tuner lock as far as I remember.
                Education is not the learning of facts, But the training of the mind to think
                So hit the thanks button if I have enlightened you.
                • scottj130208
                  • Apr 2011
                  • 323
                  SOLVED it was the image latest vix image could not find channels with auto bouquet maker
                  changed image to vix hades and bingo all channels now picked up thanks for the help but fixed it me self in the end
                  • cactikid
                    • 12017
                    strange having to go back to a previous image to get it to work and updates will not be possible with hades.
                    i know abm does not work in southern ireland even with netid.
                    • scottj130208
                      • Apr 2011
                      • 323
                      Not really bothered about updates just glad I got it to work in the end
                      • epsonsx130
                        • Feb 2014
                        I have Zgemma H2H, having the same problem (southren Ireland) tried everything with new vix images. Correct netid etc. Also getting SRN 29% tried with splitter without splitter, in my house and in friends house nothing worked. Send the box back and got replacement but still the same problem (Auto bouquets time out lock on vermin)
                        . Cactikid saying " abm does not work in southren Ireland" any alternative?
                        How did you resolve you resolve by installing vix hades. Can you please explian step by step as not very technical mind? Sat part working fine. Help pleas
                        • lincsat
                          • 1228
                          There has been a discussion on the ViX forum about ABM in Southern Ireland, the providers there us a slightly different system to the UK. You should be able to do a manual scan with network search set to on, it will not sort the channels into bouquets though, you would have to do that yourself.
