Edited as nobody was able to produce full spec breakdown for ZGEMMA, Info found on openpli wiki, Note Zgemma is found halfway down the list, hope this helps others out.
After reading the full spec breakdown i opted for the Mutant HD51 being a 4k box with a healthy 1.7 ghz cpu and double ram to the Zgemma,
Also the ability to change out the tuners and add in more tuners, I am now able to have dual sat + dual cable in one box
SET-TOP-BOX COMPARISON
In the table below you will find most of the STB's supported by OpenPLi, with their technical specifications, real power consumption figures, and the OpenPLi version supported for the model. Please note that this list shows only relevant differences between STB's. Features that are shared by all (like digital S/PDIF audio out) are left out.
VU+
*A PVR means fully-featured recording settop-box, Zapper means watching only, no recording, no streaming.
*B The vendor may sell both single and dual tuners, so there may be one or two tuners in one slot.
*C This excludes USB harddisks, because they can always be connected regardless. Connectors are (e)SATA unless otherwise noted.
*D Limited transcoding means: only one (small) resolution, quality is poor. Standby means: only operable in standby.
*E Limited means: SD full motion and HD I-frames only (pictures gets updated 1-2 times a second)
Zgemma
*1 Using OpenOpera browser, not supplied by the manufacturer, not supported, not tested, no guarantees.
Golden Media Golden Interstar Xpeed LX
XTrend
*2 The ET10000 has two ethernet ports, the 1Gbps port does not function correctly on many of them
Edision
*2 There are 4 different hardware models: 1 x DVB-S2, 1 x DVB-T2, 2 x DVB-S2, 1 x DVB-S2 + 1 x DVB-T2
*3 Embedded 802.11n Wifi interface, Embedded Bluetooth interface
Xsarius
Formuler
Mut@nt
Max digital (end-of-sale models)
Mut@nt (end-of-sale models)
XTrend (end-of-sale models)
VU+ (end-of-sale models)
*1 Only one of the pluggable tuners may be a dual tuner, bringing the total possible to 4 tuners.
Dream Multimedia (end-of-sale models, no longer supported)
Note that OpenPLi has stopped with all active support for hardware from
Dream Multimedia. Newer models, including dm500hd v2, dm800se v2, dm7020hd v2 and
the dm7080hd will not receive support from OpenPLi due to DMM closing up their
sources. Please see the official OpenPLi statement on the homepage
Support for these end-of-sale models is "as-is". Other than the OpenPLi version listed in
the table, there will be no further development for these STB's.
Dream Multimedia (end-of-life models, no longer supported)
VU+
| Type STB *A | Zapper | Zapper | PVR | PVR | PVR | PVR |
| OpenPLi | ||||||
| Support status | 4 | 4 | 4 | 4 | 4 | 4 |
| Tuners | ||||||
| Fixed / pluggable | 1/- | -/1 | 2/- | -/2 | -/1 | 1/1 |
| Fixed tuners (single/dual) *B | 1xS | - | 2xS | - | - | - |
| Fixed tuners (FBC) | - | - | - | - | - | S |
| Pluggable tuners (single/dual) | - | S/C/C+T | - | S/C/C+T | S/C/C+T | S/C/C+T |
| Pluggable tuners (FBC) | - | - | - | - | S/C+T | - |
| Media | ||||||
| Other manufacturers remote control | - | - | - | - | - | - |
| CI | - | 1 | 1 | 2 | 1 | 1 |
| Smart card | 1 | 1 | 2 | 2 | 1 | 2 |
| HDMI | 1 | 1 | 1 | 1 | 1 | 1 |
| HDMI-CEC | + | + | + | + | + | + |
| Component video | - | - | - | + | - | - |
| Scart | - | - | 1 | 1 | - | - |
| LNB pass-through | - | + | - | pluggable | pluggable | pluggable |
| Cable pass-through | - | - | - | - | pluggable | pluggable |
| User interface | ||||||
| HBBTV / browser | + | + | + | + | - | - |
| Display | 1 LED | 1 LED | VFD text | VFD 140x32 | - | LCD 480x320 |
| Miscellaneous interfaces | ||||||
| Ethernet Mbps | 100 | 100 | 1000 | 1000 | 1000 | 1000 |
| USB 2.0 host | 2 | 2 | 3 | 3 | 2 (2xSS) | 3 (2xSS) |
| Storage | ||||||
| Harddisk internal *C | - | - | 2.5" | 2.5/3.5" | - | 2.5" bay |
| Harddisk external *C | - | + | - | + | - | - |
| Other memory | - | - | - | - | - | - |
| Internal | ||||||
| SoC | bcm7362 | bcm7241 | bcm7356 | bcm7424 | bcm7252s | bcm7376 |
| Architecture | mips32el | mips32el | mips32el | mips32el | armv7ahf-neon | armv7ahf-neon |
| CPU Mhz | 742 | 1300 | 1300 | 1300 | 1700 | 1500 |
| Cores | 1 | 1 | 1 | 1 | 2 | 2 |
| Threads | 2 | 2 | 2 | 2 | 2 | 2 |
| RAM total MiB | 512 | 1024 | 1024 | 2048 | 2048 | 2048 |
| RAM available MiB | 570 | 965 | 214 | |||
| Flash size MiB | 256 | 256 (512) | 256 | 1024 | 4096 (eMMC) | 4096 (eMMC) |
| Video resolution | HD-p | HD-p | HD-p | HD-p | UHD | UHD |
| Transcoding *D | - | limited | limited | + | + | + |
| PiP *E | - | full | full | full | full | full |
| HEVC decoding in DVB | - | - | - | - | + | + |
| HEVC decoding in media | - | - | - | - | + | + |
| Linux kernel | 3.13 | 3.13 | 3.13 | 3.13 | 3.14 | 3.14 |
| Delayed decoding | - | - | - | - | - | - |
| Demuxers (all/CA) | 9/9 | 13/13 | 14/14 | |||
| OSD layer | HD | HD | HD | HD | HD | HD |
| Power | ||||||
| Active | 9 W | 16 W | ||||
| Stand by | 8 W | 14 W | ||||
| Miscellaneous | ||||||
| additional colour LCD | colour LCD + live view | |||||
Zgemma
| Type STB *A | PVR | PVR | PVR | PVR | PVR | PVR |
| OpenPLi | ||||||
| Tuners | ||||||
| Fixed / pluggable | 1/0 | 2/0 | 2/0 | 2/0 | 1/0 | 2/0 |
| Fixed tuners | 1xS | 2xS | 1xS/1xC | 1xS/1xC+T2 | 1xS | 2xS |
| Available pluggable tuners B | - | - | - | - | - | - |
| Media | ||||||
| Other manufacturers remote control | + | + | + | + | + | + |
| CI | - | - | - | - | - | - |
| Smart card | 1 | 1 | 1 | 1 | 1 | 1 |
| Composite video | + | + | + | + | + | + |
| Scart | - | - | - | - | - | - |
| LNB pass-through | - | pluggable | - | - | - | pluggable |
| Cable pass-through | - | - | - | - | - | - |
| HBBTV / browser | *1 | *1 | *1 | *1 | *1 | *1 |
| Display | 4x7segment | 4x7segment | 4x7segment | 4x7segment | 4x7segment | 4x7segment |
| Ethernet Mbps | 100 | 100 | 100 | 100 | 100 | 100 |
| USB 2.0 host | 2 | 2 | 2 | 2 | 2 | 2 |
| Storage | ||||||
| Harddisk internal *C | - | - | - | - | - | - |
| Harddisk external *C | - | - | - | - | - | - |
| Other memory | - | - | - | - | SD | SD |
| Internal | ||||||
| SoC | bcm7358 | bcm7358 | bcm7358 | bcm7358 | bcm7362 | bcm7362 |
| Architecture | mips32el-nf | mips32el-nf | mips32el-nf | mips32el-nf | mips32el | mips32el |
| CPU MHz | 750 | 750 | 750 | 750 | 750 | 750 |
| Cores | 1 | 1 | 1 | 1 | 1 | 1 |
| Threads | - | - | - | - | 2 | 2 |
| RAM total MiB | 512 | 512 | 512 | 512 | 512 | 512 |
| RAM available MiB | ||||||
| Flash size MiB | 256 | 256 | 256 | 256 | 256 | 256 |
| Video resolution | HD-p | HD-p | HD-p | HD-p | HD-p | HD-p |
| Transcoding *D | - | - | - | - | - | - |
| PiP *E | - | - | - | - | - | - |
| HECV decoding in DVB | - | - | - | - | - | - |
| HECV decoding in media | - | - | - | - | - | - |
| Linux kernel | 4.0.1 | 4.0.1 | 4.0.1 | 4.0.1 | 4.0.1 | 4.0.1 |
| Delayed decoding | + | + | + | + | + | + |
| Demuxers (all/CA) | 7/7 | 7/7 | 7/7 | 7/7 | 8/8 | 8/8 |
| OSD layer | 720 | 720 | 720 | 720 | HD | HD |
| Power | ||||||
| Active | ||||||
| Stand by | ||||||
| OpenPLi | ||
| Tuners | ||
| Fixed / pluggable | 2/0 | 2/0 |
| Fixed tuners | 1xS,1xC+T2 | 1xS,1xC+T2 |
| Available pluggable tuners *B | - | - |
| Media | ||
| CI | - | - |
| HDMI | 1 | 1 |
| HDMI-CEC | + | + |
| Component video | + | + |
| Scart | - | - |
| LNB pass-through | - | - |
| User interface | ||
| Storage | ||
| Other memory | SD | SD |
| Internal | ||
| SoC | bcm7362 | bcm73625 |
| CPU Mhz | 750 | 750 |
| Cores | 1 | 1 |
| Threads | 2 | 2 |
| PiP *E | - | - |
| HEVC decoding in DVB | - | SD/HD |
| Demuxers (all/CA) | 8/8 | 8/8 |
| Power | ||
| Active | ||
| Stand by | ||
| Miscellaneous | ||
| OpenPLi | ||
| Tuners | ||
| Fixed / pluggable | 1/- | 1/- |
| Fixed tuners | S | C |
| Media | ||
| CI | - | - |
| HDMI | 1 | 1 |
| HDMI-CEC | ||
| Scart | - | - |
| Cable pass-through | - | + |
| User interface | ||
| Display | 2 leds | 2 leds |
| USB 2.0 host | 1 | 1 |
| Storage | ||
| Internal | ||
| SoC | bcm7362 | bcm7362 |
| Cores | 1 | 1 |
| Threads | 2 | 2 |
| RAM available MiB | 240 | 240 |
| PiP *E | - | - |
| Linux kernel | 3.18 | 3.18 |
| Power | ||
| Active | ||
| Stand by | ||
| Miscellaneous | ||
XTrend
| OpenPLi | ||||
| Tuners | ||||
| Fixed / pluggable | 1/- | 1/1 | -/4 | -/4 |
| Fixed tuners | S | S | - | - |
| Available pluggable tuners *B | - | S/C+T | S/C+T | S/C+T |
| Media | ||||
| Other manufacturers remote control | - | - | - | + |
| CI | 1 | 1 | 1 | 2 |
| Smart card | 1 | 2 | 2 | 2 |
| HDMI | 1 | 1 | 1 | 1 out / 1 in |
| Scart | - | - | - | 1 |
| LNB pass-through | - | pluggable | + | + |
| HBBTV / browser | *1 | *1 | + | + |
| Display | 2 LED | VFD text | LCD tv output | VFD 128x32 |
| Ethernet Mbps | 100 | 100 | 1000 | 100+1000 *2 |
| USB 2.0 host | 2 | 2 | 3 | 5 |
| Storage | ||||
| Harddisk internal *C | - | 2.5" | 2.5" | 3.5" |
| Harddisk external *C | + | + | + | + |
| Internal | ||||
| SoC | bcm7362 | bcm7362 | bcm7241 | bcm7424 |
| CPU Mhz | 750 | 750 | 1300 | 1300 |
| RAM total MiB | 512 | 512 | 1024 | 2048 |
| RAM available MiB | 248 | 248 | 300 | 1257 |
| Flash size MiB | 256 | 256 | 512 | 1024 |
| Transcoding *D | - | - | - | + |
| PiP *E | - | - | + | + |
| Linux kernel | 3.14 | 3.14 | 3.14 | 4.01 |
| Delayed decoding | - | - | - | + |
| Demuxers (all/CA) | 7/7 | 8/8 | ||
| Power | ||||
| Active | 14 | 22.4 | ||
| Stand by | 13 | 3 | ||
Edision
| OpenPLi | |||
| Tuners | |||
| Fixed / pluggable | *2/- | 1/- | 3/- |
| Fixed tuners | *2 | S2/S/T2/T/C | 2*S2+S2/S/T2/T/C |
| Available pluggable tuners *B | - | - | - |
| Media | - | - | |
| CI | - | - | 1 |
| HDMI | 1 | 1 | 1 |
| Scart | - | - | - |
| LNB pass-through | - | - | - |
| Display | 4x7segment | VFD (8 digits) | VFD (12 digits) |
| Ethernet Mbps | 100 *3 | 1000 *3 | 1000 *3 |
| Storage | |||
| Harddisk internal *C | - | - | + |
| Harddisk external *C | - | - | + |
| Internal | |||
| SoC | bcm7362 | bcm73625 | bcm73465 |
| CPU Mhz | 751 | 751 | 1600 |
| Cores | 1 | 1 | 1 |
| RAM available MiB | 568 | ||
| Flash size MiB | 512 | 512 | 512 |
| HEVC decoding in DVB | - | SD/HD | SD/HD |
| HEVC decoding in media | - | SD/HD | SD/HD |
| Linux kernel | 4.9.0 | 4.9.0 | 4.9.0 |
| Demuxers (all/CA) | 5/5 | 5/5 | 7/7 |
| Power | |||
| Active | |||
| Stand by | |||
| Miscellaneous | |||
Xsarius
| OpenPLi | ||
| Tuners | ||
| Fixed / pluggable | 2/- | 1/1 |
| Fixed tuners | C+S | S |
| Available pluggable tuners *B | - | S/C/C+T |
| Media | ||
| CI | 1 | - |
| HDMI | 1 | 1 |
| HDMI-CEC | - | - |
| Scart | - | - |
| Cable pass-through | + | pluggable |
| User interface | ||
| Display | 3 leds | 3 leds |
| Storage | ||
| Harddisk internal *C | 2.5" | 2.5" |
| Other memory | - | |
| Internal | ||
| Cores | 1 | 1 |
| Threads | 2 | 2 |
| RAM available MiB | 237 | 237 |
| PiP *E | - | - |
| Linux kernel | 4.2.1 | 4.2.1 |
| Power | ||
| Active | ||
| Stand by | ||
| Miscellaneous | ||
Formuler
| OpenPLi | ||||
| Tuners | ||||
| Fixed / pluggable | 1/- | 1/- | 1/1 | 2/1 |
| Fixed tuners | S | S | S | S |
| Available pluggable tuners *B | - | - | C/T | S/C+T |
| Media | ||||
| CI | 1 | 1 | 1 | 1 |
| Smart card | 1 | 1 | 1 | 2 |
| Component video | + | + | - | + |
| LNB pass-through | - | - | pluggable | pluggable |
| Cable pass-through | - | - | pluggable | pluggable |
| HBBTV / browser | - | - | - | - |
| Display | LED 4x7 seg | LED 4x7 seg | LED 4x7 seg | VFD text |
| Ethernet Mbps | 100 | 100 | 100 | 1000 |
| USB 2.0 host | 2 | 3 | 2 | 3 |
| Storage | ||||
| Harddisk external *C | - | - | - | + |
| Other memory | SD | SD | SD | |
| Internal | ||||
| SoC | bcm7362 | bcm7362 | bcm73625 | bcm7356 |
| CPU Mhz | 750 | 750 | 750 | 1100 |
| RAM total MiB | 512 | 512 | 1024 | |
| RAM available MiB | 314 | 314 | 512 | |
| Flash size MiB | 256 | 256 | 512 | |
| PiP *E | - | - | - | + |
| HEVC decoding in DVB | - | - | + | - |
| HEVC decoding in media | - | - | - | |
| Linux kernel | 4.01 | 4.01 | 4.01 | |
| Demuxers (all/CA) | 8/8 | |||
| Power | ||||
| Active | 6.9 | 13.5 | ||
| Stand by | 9 | |||
Mut@nt
| OpenPLi | |||||
| Tuners | |||||
| Fixed / pluggable | -/2 | 1/- | 1/- | 2/- | -/4 |
| Fixed tuners | - | C | S | S | - |
| Available pluggable tuners *B | S/C+T+T2 | - | - | - | S/C/C+T |
| Media | |||||
| CI | 1 | - | - | 1 | 2 |
| Smart card | 1 | 1 | 1 | 1 | 2 |
| HDMI | 1 | 1 | 1 | 1 | 1 in/1 out |
| HDMI-CEC | + | - | + | + | + |
| Component video | - | - | - | - | +, rev2 - |
| Scart | AV | AV | 1 | - | 1 |
| LNB pass-through | + | - | - | + | + |
| Cable pass-through | + | - | - | - | + |
| HBBTV / browser | - | *1 | *1 | *1 | *1 |
| Display | VFD 12segment | LED 4x7 seg | LED 4x7 seg | LED 4x7 seg | OLED 256x64 |
| Ethernet Mbps | 1000 | 100 | 100 | 100 | 1000 |
| USB 2.0 host | 2, 1x USB3 | 1 | 1 | 1 | 3 |
| Storage | |||||
| Harddisk internal *C | 2.5" | - | - | - | 2.5" |
| Internal | |||||
| SoC | bcm7251s | bcm7581 | bcm7362/73625 | bcm73625 | bcm7424 |
| Architecture | armv7ahf-neon | mips32el-nf | mips32el | mips32el | mips32el |
| CPU Mhz | 1700 | 750 | 750 | 750 | 1300 |
| Cores | 2 | 1 | 1 | 1 | 1 |
| Threads | - | - | 2 | 2 | 2 |
| RAM total MiB | 1024 | 256 | 512 | 512 | 2048 |
| Flash size MiB | 4096 | 128 | 256 | 256 | 1024 |
| Video resolution | UHD-p | HD-p | HD-p | HD-p | HD-p |
| Transcoding *D | - | - | - | - | + |
| PiP *E | + | - | - | - | + |
| HEVC decoding in DVB | + | - | 1200:-,1265:+ | - | - |
| HEVC decoding in media | - | - | - | - | - |
| Linux kernel | 4.7.4 | 4.7.4 | 4.7.4 | 4.7.4 | 4.7.4 |
| Demuxers (all/CA) | 14/8 | 7/7 | 8/8 | 8/8 | 8/8 |
| OSD layer | HD | 720 | HD | HD | HD |
| Power | |||||
| Active | 12/9 | 5.0 | |||
| Stand by | 6 | 6.6 | |||
| Type STB *A | PVR |
| OpenPLi | |
| Tuners | |
| Fixed tuners | S |
| Media | |
| CI | 1 |
| Smart card | 2 |
| HDMI | 1 |
| HDMI-CEC | + |
| Scart | 1 |
| User interface | |
| Display | - |
| USB 2.0 host | 1 |
| Storage | |
| Other memory | - |
| Internal | |
| SoC | bcm7358 |
| CPU Mhz | 500/600/750 |
| Cores | 1 |
| Threads | - |
| RAM available MiB | 230 |
| Flash size MiB | 128 |
| PiP *E | - |
| Demuxers (all/CA) | |
| OSD layer | 720 |
| Power | |
| Active | 10 |
| Stand by | 8 |
| Miscellaneous | |
| Type STB *A | PVR |
| OpenPLi | |
| Tuners | |
| Fixed tuners | S |
| Media | |
| Other manufacturers remote control | |
| CI | - |
| Smart card | 1 |
| HDMI | 1 |
| HDMI-CEC | + |
| Scart | 1 |
| User interface | |
| Display | - |
| USB 2.0 host | 1 |
| Storage | |
| Other memory | - |
| Internal | |
| SoC | bcm7358 |
| Cores | 1 |
| Threads | - |
| PiP *E | - |
| OSD layer | 720 |
| Power | |
| Active | |
| Stand by | |
| Miscellaneous | |
| Type STB *A | PVR | PVR | PVR | PVR | PVR | PVR | PVR | PVR |
| OpenPLi | ||||||||
| Support status | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
| Tuners | ||||||||
| Fixed / pluggable | 1/- | 1/- | 1/- | -/1 | -/3 | 2/- | 2/- | -/2 |
| Fixed tuners | S | S | S | - | - | S | S | - |
| Available pluggable tuners *B | - | - | - | S/C/T | S/C/T | - | - | S/C/T |
| Media | ||||||||
| Other manufacturers remote control | + | + | + | + | + | + | + | + |
| CI | - | - | - | - | 2 | 2 | 2 | 2 |
| Smart card | 2 | 2 | 1 | 2 | 2 | 2 | 2 | 2 |
| HDMI | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| HDMI-CEC | + | + | + | + | + | + | + | + |
| Component video | - | + | + | + | + | + | + | + |
| Scart | 1 | 1 | 1 | 1 | 1 | 2 | 2 | 2 |
| LNB pass-through | - | + | + | + | + | + | + | + |
| Cable pass-through | - | - | - | - | - | - | - | - |
| User interface | ||||||||
| HBBTV / browser | *1 | + | + | + | + | + | + | + |
| Display | - | - | - | VFD text | VFD text | VFD text | VFD text | VFD text |
| Miscellaneous interfaces | ||||||||
| Ethernet Mbps | 100 | 100 | 100 | 100 | 1000 | 100 | 100 | 100 |
| USB 2.0 host | 2 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
| Storage | ||||||||
| Harddisk internal *C | - | - | - | 2.5" | 3.5" | 3.5" | 3.5" | 3.5" |
| Harddisk external *C | - | - | - | - | + | - | - | - |
| Other memory | - | - | - | - | - | - | - | - |
| Internal | ||||||||
| SoC | bcm7358 | bcm7413 | bcm7413 | bcm7413 | bcm7241 | bcm7413 | bcm7413 | bcm7413 |
| Architecture | mips32el-nf | mips32el | mips32el | mips32el | mips32el | mips32el | mips32el | mips32el |
| CPU Mhz | 500/600/750 | 400 | 400 | 400 | 1300 | 400 | 400 | 400 |
| Cores | 1 | 2 | 2 | 2 | 1 | 2 | 2 | 2 |
| Threads | - | - | - | - | 2 | - | - | - |
| RAM total MiB | 512 | 256 | 512 | 512 | 1024 | 512 | 512 | 512 |
| RAM available MiB | 290 | 495 | 290 | 290 | 290 | |||
| Flash size MiB | 128 | 128 | 1024 | 512 | 128 | 256 | 1024 | |
| Video resolution | HD-p | HD-i | HD-i | HD-i | HD-p | HD-i | HD-i | HD-i |
| Transcoding *D | - | - | - | - | - | - | - | - |
| PiP *E | - | limited | limited | limited | + | limited | limited | limited |
| Linux kernel | 3.8 | 3.8 | 3.8 | 4.01 | 3.8 | 3.8 | 3.8 | |
| Delayed decoding | + | + | + | + | + | + | + | + |
| Demuxers (all/CA) | 7/7 | 7/7 | 7/7 | |||||
| OSD layer | 720 | 720 | HD | HD | HD | HD | HD | HD |
| Power | ||||||||
| Active | 10 | 35 | 16 | 28 | 26-50 | |||
| Stand by | 5 | 12 | 23 | 21 | ||||
| Miscellaneous | ||||||||
| Type STB *A | PVR | PVR | PVR | PVR | |||
| OpenPLi | |||||||
| Support status | 4 | 4 | 4 | 4 | |||
| Tuners | |||||||
| Fixed / pluggable | 1/- | 2/- | -/1 | -/3 *1 | |||
| Fixed tuners | 1xS | 2xS | - | - | |||
| Available pluggable tuners *B | - | - | S/C/T/C+T | S/C/T/C+T | |||
| Media | |||||||
| Other manufacturers remote control | - | - | - | - | |||
| CI | 2 | 2 | 2 | 2 | |||
| Smart card | 1 | 2 | 2 | 2 | |||
| HDMI | 1 | 1 | 1 | 1 | |||
| HDMI-CEC | + | + | + | + | |||
| Component video | 1 | 1 | - | + | |||
| Scart | 1 | 2 | 1 | 1 | |||
| LNB pass-through | - | - | + | + | |||
| Cable pass-through | - | - | - | - | |||
| HBBTV / browser | + | + | + | + | |||
| Display | - | VFD text | VFD text | VFD text | |||
| Ethernet Mbps | 100 | 100 | 100 | 100 | |||
| USB 2.0 host | 2 | 3 | 3 | 3 | |||
| Storage | |||||||
| Harddisk internal *C | - | 3.5" | 2.5"/3.5" | 2.5"/3.5" | |||
| Harddisk external *C | - | + | + | + | |||
| Other memory | - | - | - | - | |||
| Internal | |||||||
| SoC | bcm7325 | bcm7335 | bcm7413 | bcm7413 | |||
| Architecture | mips32el | mips32el | mips32el | mips32el | |||
| CPU Mhz | 333 | 400 | 400 | 400 | |||
| Cores | 1 | 1 | 2 | 2 | |||
| Threads | - | - | - | - | |||
| RAM total MiB | 256 | 384 | 512 | 512 | |||
| RAM available MiB | 109 | 135 | 270 | ||||
| Flash size MiB | 128 | 128 | 128 | 1024 | |||
| Video resolution | HD-i | HD-i | HD-i | HD-i | |||
| Transcoding *D | - | - | - | - | |||
| PiP *E | - | - | limited | limited | |||
| Linux kernel | 3.9.6 | 3.9.6 | 3.9.6 | 3.9.6 | |||
| Delayed decoding | - | - | - | - | |||
| Demuxers (all/CA) | 5/5 | 9/9 | |||||
| OSD layer | 720 | HD | HD | HD | |||
| Power | |||||||
| Active | 20 | 22 | 33 | ||||
| Stand by | 17 | 16 | 31 | ||||
| WLAN 802.11n USB dongle | |||||||
| OpenPLi | ||||
| Tuners | ||||
| Fixed / pluggable | 2/2 | 1/- | -/1 | -/2 |
| Fixed tuners | 2xS | 1xS | - | - |
| Available pluggable tuners *B | S/C/T/C+T | - | S/C/T/C+T | S/C/T/C+T |
| Media | ||||
| CI | 4 | - | - | 2 |
| Smart card | 2 | 1 | 2 | 2 |
| HDMI | 1 (DVI-to-HDMI required!) | 1 | 1 | 1 |
| HDMI-CEC | - | + | + | + |
| Component video | + | - | - | - |
| Scart | 2 | 1 | 1 | 1 |
| LNB pass-through | pluggable | - | + | pluggable |
| Display | OLED graphics | - | OLED graphics colour | OLED graphics |
| USB 2.0 host | 3 | - | 2 | 3 |
| Storage | ||||
| Harddisk internal *C | 3.5"+DVD | - | 2.5" | 3.5" |
| Other memory | CF | - | - | - |
| Internal | ||||
| SoC | bcm7400d2 | bcm7405 | bcm7405 | bcm7405 |
| CPU Mhz | 400 | 400 | 400 | 400 |
| Threads | 2 | - | - | - |
| RAM total MiB | 256 | 256 | 256 | 512 |
| RAM available MiB | 146 | 132 | ||
| Flash size MiB | 128 | 64 | 64 | 1024 |
| PiP *E | full | - | - | limited |
| Linux kernel | 3.2 | 3.2 | 3.2 | 3.2 |
| Demuxers (all/CA) | 5/4 | 5/4 | 5/4 | |
| Power | ||||
| Active | 31 | |||
| Stand by | 27 | |||
| Internal PCI WLAN adapter 802.11bg DTS Passthrough S/PDIF Software DTS downmix |
Software DTS downmix | Software DTS downmix | Software DTS downmix | |
| Type STB *A | PVR | |||
| OpenPLi | ||||
| Support status | 2.1 | |||
| Tuners | ||||
| Fixed / pluggable | -/1 | |||
| Fixed tuners | - | |||
| Available pluggable tuners *B | S/C/T/C+T | |||
| Media | ||||
| Other manufacturers remote control | - | |||
| CI | - | |||
| Smart card | 1 | |||
| HDMI | 1 (DVI-to-HDMI required!) | |||
| HDMI-CEC | - | |||
| Component video | - | |||
| Scart | 1 | |||
| LNB pass-through | + | |||
| Cable pass-through | - | |||
| HBBTV / browser | - | |||
| Display | OLED graphics | |||
| Ethernet Mbps | 100 | |||
| USB 2.0 host | 3 | |||
| Storage | ||||
| Harddisk internal *C | 2.5" | |||
| Harddisk external *C | - | |||
| Other memory | - | |||
| Internal | ||||
| SoC | bcm7401 | |||
| Architecture | mips32el-nf | |||
| CPU Mhz | 300 | |||
| Cores | 1 | |||
| Threads | - | |||
| RAM total MiB | 256 | |||
| RAM available MiB | 180 | |||
| Flash size MiB | 64 | |||
| Video resolution | HD-i | |||
| Transcoding *D | - | |||
| PiP *E | - | |||
| Linux kernel | 2.6.18 | |||
| Delayed decoding | - | |||
| Demuxers (all/CA) | 4/4 | |||
| OSD layer | 720 | |||
| Power | ||||
| Active | ||||
| Stand by | ||||
| SoC does not support MPEG4-VC | ||||
