AZbox Premium HD-mgcamd
  • Orion
    • 12
    Just getting use to azbox, can someone explain what the difference is between the, mgcamd 1.33 and redbulls mgcamd autoroll etc.
    I read somewhere not to use the standard mgcamd, is there three different versions.
    Any help appreciated.
  • stavross
    • 44
    Redbulls is used to auto update the K@ys where as any other mgcamd version will work but no auto update?????
    Becuse I use satelites as well I have added the K@ys into the K@y bin in multicas so I d'ont have to flick between the two
    Hope this helps M8
    Stavross
    • Orion
      • 12
      Thanks, Stavross, that info has helped me a lot, this is my first Linux box, and a whole new leaning experience.
      Cheers
      Orion
      • SuperSat
        • 365
        Azbox is supposed to be a very good box!!!
        wellDone!!!
        Technomate 6800 HD/DM800 HD PVR
        1.1 metre Dish
        Darkmotor
        SuperSat
        http://www.youtube.com/watch?v=kyFyAqLtHq8
        http://www.digital-kaos.co.uk/forums...0192-supersat/
        • sagasi2009
          Hi,Everyone I am planing to buy AZBOX Premium but i am not very good with linux,however i've got experience on networking.What else do I need to have except Azbox.Any help with appreciate,thanks
          • Orion
            • 12
            The Azbox Premium is a very good reciever and for the price good value, however i would wait and buy the Azbox Premium +, as this will have a dual tuner.
            It is easy to setup, and there is plenty of help and guides available, i done my research first downloaded a load of stuff i would need to get started and put it all in a file for reference.
            Dont forget if you do buy it buy the (+).
            It would be a help if you explain what type of system you have at the present.
            Last edited by Orion; 21 December, 2009, 09:31. Reason: To insert the last paragraph.
            • merciless
              Hope this helps M8
              Dragging an old thread up i know but my question has been addressed in here so what the hell.
              Stavross i have pretty much the same setup as you and would like to avoid the need to switch between the two.
              How did you go about adding the k@ys into the k@y bin in multicas if i do it through maz it then reports the file size as 1kb which i've heard won't work it needs to be 37.
              Did you use multicas edit? and if so what goes in what column provider name provider etc.
              • strzyzol
                • Feb 2010
                • 232
                MultiCAS 162D-A01 it more stable than mgcamd. As for the Premium + is a bit too loud fan they installed.
                MultiCAS-v162D-A01.tgz
