Box Update Advice Needed BEST Box 2017
  • clarkenuttal
    • Mar 2010
    • 47
    With Sly now going Dark I want to move towards VM and update my box.
    1) Ideally something that can have a cable feed (For Normal Channels) and satellite feed (For FTA Channels).
    2) Ideally something that can allow recording another channel while watching different channel.
    3) HD Compatible.
    4) Budget is Flexible around ?300 but consideration will be given to budget versus benefit ratio.
    5) Good to have added features such as KODI, IPTV etc but that's not compulsory
    I am very na?ve with technology so please excuse me for my limited knowledge
  • aftermath
    • 4345
    VU DUO 2, might be a tad more in cost but a superb box, can have 2 duel tuners any combination.
    • P&D
      • 2685
      Good box........but nothing the OP will buy is plug & play like the openbox
      a lot more in put from the user is needed.........& a lot of reading
      • clarkenuttal
        • Mar 2010
        • 47
        Isn't this box a bit old? How does that compare to Vu 4K? Is there any other box in ?200-?250 mark?
        • clarkenuttal
          • Mar 2010
          • 47
          How many vermin cable inputs does Vu+ Duo 2 support at a time?
          • aftermath
            • 4345
            2 x dual tuners if you want.. so that's 4 tuners ..
            • vorlon2257
              • Sep 2011
              • 356
              Zgemma-H5.2TC
              • clarkenuttal
                • Mar 2010
                • 47
                I looked but most of them are selling as Dual S2 Tuners (4 inputs) which you referred as 4 Tuners. Will these support 4 Vermin inputs too?
                • clarkenuttal
                  • Mar 2010
                  • 47
                  Originally posted by vorlon2257
                  Zgemma-H5.2TC
                  Thanks I'll read into it. I assume it is a good box?
                  • vorlon2257
                    • Sep 2011
                    • 356
                    Yes, the same as all Zgemma's, they do exactly what the Vu+ boxs do at a fraction of the cost you just have to buy an external USB harddrive a 500 gb is more than enough to record as you can't put a harddrive into them. Supported by various images except the openvix image as they class these boxs as clones (which they are not).
                    Opena-tv is the main image for the box and is a far better image in my opinion.
                    I have 3 Zgemmas myself, a H1 H.2H and H5 they are combo boxs and all working perfect on the opena.tv image 6.0 image
                    • clarkenuttal
                      • Mar 2010
                      • 47
                      Can someone confirm if Zgemma H5.2TC can play IPTV too?
                        Simple answer Yes!
                        • clarkenuttal
                          • Mar 2010
                          • 47
                          Originally posted by digicon
                          Simple answer Yes!
                          So it can play cable and IPTV both at same time? I won't need separate box to play IPTV And Cable?
                            No! you would not even the cheaper H.2H is perfectly adequate for both Cable and IPTV reception and both can be run side by side.
                            • clarkenuttal
                              • Mar 2010
                              • 47
                              What image will I need to make IPTV and vermin both work on same box at same time? Is there any instructions available on how to flash and load these images on Zgemma boxes?
