Best Way To Split a Connection
  • clarkenuttal
    • Mar 2010
    • 47
    Guys I have a vermin broadband line and I wonder if I can split it using a splitter to get an output for my cable tv box?
    I am planning to use following Splitter:
    www.screwfix.com/p/labgear-2-way-splitter-with-power-pass-all-ports/99105
    Please advise if the method above will work or do I need a separate line for TV?
    yes you can and that splitter should work, as for getting tv on a none vermin box thats another matter.
    • clarkenuttal
      • Mar 2010
      • 47
      Thanks I wasn't sure if Broadband Line can be spitted to get TV line out. You think the splitter in the link above is good enough to do the job?
        yeh looks ok, and bb and tv come down the same cable.
        • clarkenuttal
          • Mar 2010
          • 47
          Thanks!!! Does zgemma need F Type to BL Male Adaptor too for cable?
          • Hadron
            • 2102
            Yep. More commonly known as COAX AERIAL adapters on ebay:-
            http://www.ebay.co.uk/itm/6-x-F-Type...cAAOSwHQ9WafxU
