Combo Cable + IPTV Box recommendation?
  • saayinla
    • 162
    Hi All,
    Am in the market for a combo IPTV + Cable box, any recommenations will be welcomed.
    Thanks in advance.
    PS : IS the Zgemma H2 worth it, is IPTV on it any good at all?
  • clarkenuttal
    • Mar 2010
    • 47
    Read about Zgemma H5 its pretty decent for the price you pay
    • digicon
      • 8261
      Even the most basic Zgemma H.2H will suffice for what you need
      • happy_highlander
        • Aug 2010
        • 3535
        If your going to use one of the first gen zgemma like the h2 or 2s for iptv I'd advise a lightweight build such as openpli. I've found openatv 6.0 way to system intensive to stream iptv consistently. Whereas on pli 4.0 the same iptv streams are almost faultless.
        Sent from my SM-G935F using Tapatalk
        • pudzy
          • 206
          I'm using, amiko mini combo, terrestrial, free to air , and iptv , picture is great .
          • saayinla
            • 162
            Thanks all for your suggestions.
            I went with the H5 but it seems a bad choice as I have ordered a second box and the turner does not seem up to scratch due to the image distortion, its completely unusable.
            Might just have to go back to one of the early gen ones.
            • clarkenuttal
              • Mar 2010
              • 47
              Use Zgemma H5-2TC it has single sat tuner and twin Cable Tuners. You can get one easily for ?100 and it does decent job. Flash it with Whooshbuild you would like it
              • saayinla
                • 162
                Thanks for the suggestions, I have bought the standard H5 boxes from 2 seperate sellers on ebay and both had serious image distortion, see attached pictures.
                You reckon the H5.2TC has a better tuner?
                • happy_highlander
                  • Aug 2010
                  • 3535
                  If those images are on fta broadcast you need to be checking your cables/connections
                  • cunny
                    • 4915
                    Even if they were not on fta you need to check your connection (as mentioned) as that looks like bad signal.
                    • cactikid
                      • 12017
                      agreed if on cable how old is cabling and what splitters in use, you might need to post a picture of cables and splitters and any attenuators fitted?
                      • saayinla
                        • 162
                        Thanks for all your time to respond, What I also forgot to mention is that I have a Vu+ Cable USB tuner which I use on my existing VuSolo2 box using the same Vir Cable. Works 100% Perfectly on all channels fta or otherwise, so this distortion is only being experienced on this Zgemma H5 boxes I have tried. I have also used the same cables to setup a zgemma h2 with ybrid tuner works perfectly fine.
                        Cabling was installed about 6 months ago. and here is the splitter in use which like I said works perfectly with my Cable USB tuner and on older generation zgemma cable boxes.
                        • P&D
                          • May 2010
                          • 2686
                          What S/R are you getting on each box ?
                          If good on the VU & crap on the Zge
                          disconnect the VU see if the other then works ok
                          My S/R is 22% works perfect on my Solo
                          • cactikid
                            • 12017
                            ahh the wrong splitter again as vm use a 5-1000mhz one and your one will let in interference,and what type quality of cables in use might also be bad,interesting as a better quality built box has no issues.
