This Backup Image is for the Newer H series of Zgemma Satellite receivers, it will work on the H.S and H.2s and confirmed working on the H.2H by Hadron @post #116 (requires additional setup for cable see post #119) but hasn't been tested on the H5
Openatv5.3 Backup Image with New improved Sky Skin, OTA update safe
It's set up for satellite, but works fine for the cable tuner as well. You will need to set a few things up yourself. I've posted a few basics in the thread for cable.
