No sound.
  • accies
    • 95
    No sound.
    Hi,I've lost the sound on a few channels on my Zgemma H5. 2tc on virgin. Played about with Audio settings but no joy. Anyone had same problem fixed?
  • grahampaull
    • Mar 2012
    • 48
    There is an issue with Virmin at the minute, this seems to be affecting genuine customers too. Have a look on Twitter and the VM forums.
    Sent from my SM-G950F using Tapatalk
    • accies
      • 95
      Thanks for that,it seems is the HD not Sd that's affected.
      • grahampaull
        • Mar 2012
        • 48
        Yeah, SS Main Events HD and Sky News HD has lost all sound, CH4 HD has audio description and movies HD has audio description too along with multiple others.
        • accies
          • 95
          That's a relief thought me box was Donald .
            You can do a fix your self it inloves getting the PIDS from your box for said channels and rewriting them in a channel editor. Or just wait for vermin to fix it.
            • loncell
              • 625
              Can you get the correct PID's from a subbed TeaVo ?
                Not to sure mate but the ones to try are 109 109 131 or 141
                • lincsat
                  • 1228
                  The latest ABM config files do have a patch for most HD channels. Update your ABM configs and run it again. If using OScam, make sure you're using oscam-latest
                    For some reason not updating in the north west
                    • accies
                      • 95
                      It's not clearing in South East either?
                        You need to be running a recent image for you to get the config file, there was an update to ABM only yesterday as well. if your running quite an old image you may well find yourself stuck
                        • accies
                          • 95
                          Open ATV 6.0 is that new enough?
                            Afraid not no longer supported you will need the latest up to date version you can install of 6.1 which is built Daily, so if you flash todays image you will have all the latest updates installed including the ones for ABM
                            • grahampaull
                              • Mar 2012
                              • 48
                              Is abm built into openatv 6.1?
                              I currently use ipab but it seems I'll need to upgrade to take advantage.
