dm500-c Commando 15.1E "No Valid Bouquets Found" after scan
  • stoneringers
    • 43
    I have had to revert to using a DM500-C with commando 15.1e image.
    I powered the box on and was able to view several channels ok but since I did the last scan a large number of channels have moved.
    So I did a new scan having setup my location as before (Lichfield) 00015, 642250, 6887. After a few seconds the scan failed with channel not available and the image recovered the bouquets. However after doing a brute force which did not find anything the image could no longer recover the bouquets. Further attempts at a scan resulted in No valid Bouqets found. I know my scanner and connection are good as I could orginally view a range of channels. There is no other nearby local area that I can try
  • stoneringers
    • 43
    I have restored an old version of bouquets.xml and I am now back at channel not available when i do a fast scan.
    What I am looking for is a up to date copy of bouquets.xml from the Lichfield area. If anyone can help, I would be grateful.
    • stoneringers
      • 43
      OK sorted the frequency for Lichfield has changed to 378250
      • lincsat
        • 1228
        Why not try the latest commando
        http://www.commando.org.uk/
        • stoneringers
          • 43
          I have already downloaded it and it is on my to do list. Sorting out the above frequency change problem, has put me behind.
