Hi everyone, im in the market to but a cable box, not sure which one to buy, all i want is cheap reliability, Eurovox, D box, or star veiw. if someone could give me the headsup it would be appreciated. Thanks in advance.
hi m8 u might just think again about a cable box as nag 3 is on its way soon,nobody knows when it will hit us m8 but if u want to take a chance go for a dreambox as tis has the capability to cs m8 all other boxs r useless but not that easy to set up big brov does mine via teamveiwer, good luck
cable is on nag 1 at the minute and is hacked wide open they are currently changing to nag 3 which at the moment is unhackable,cs is cardsharing but cant discuss it on here google it m8
Sorry m8 got two threads mixed up, as regards a box basically VM are changing the way they transmit there signal at the moment it is nag2 and they are changing it to nag3. At present there is no fix for nag3 so when it hits your area(the rumours have been around for ages but Leeds and IREland have already been affected)all your box will be able to receive is afew FTA channels like bbc1 etc, there may be a fix round the corner on the other hand it could be ages, you will have to think is it worth it? I run a dbox and have been very happy with it for a long time . Hope this helps a little..
so basiclly it will be like free veiw or you will just get the basic 4 channels bbc1,2 itv1 and channel 4
