Dreambox 7025 Keeps Freezing
  • smedzdave
    • 71
    Hi Guys and Gals
    I have a dm7025 with 2 cable tuners ok
    Now got all the software on and got all the channels working and everything but only got 1 problem,
    When i am watching a channel (lets just say for example) Sky Sports, The channel freezes for about a minute and then comes back to normal, then about 15-20 Mins later it freezes for about a minute and then comes back to normal, and does this continuously, Im using Mgcamd 2.14a, tried using evocam-xmas-version but that dont work,
    O yeah im also using the new LT - The Fifth Campaign for DM7025
    So can anyone help me to stop this freezing all the time cause its driving me nuts,
    Thanks in advance guys
  • westkill
    • 2378
    what image are you using m8
    just seen you edit your post
    • smedzdave
      • 71
      Yeah edited it to put in what image i was using.
      Im using
      But it did the same when i used LT- The Fourth Revolution
      • westkill
        • 2378
        Originally posted by smedzdave
        Hi Guys and Gals
        heres evocamd 2.12 and 2.13
        to try
        delete the old evocamd first
        ftp one of them to the temp folder
        then go to addons >manual install,see if that helps
        • smedzdave
          • 71
          ok ill give it a shot now and keep you posted ok pal,
          cheers
          • smedzdave
            • 71
            No mate that dont work.
            Ive tried mgcamd 130a seems to work for now but would prefer to use a evocamd so what do you recommend???
            <--smedzdave added 3 Minutes and 15 Seconds later...-->
            does anyone else also know what the best evocamd is???
            • chumu10
              • Oct 2008
              Of course, if you want to try that, you need 2 dream box 7025 and dream box 500 on a single network, Ethernet crossed cable in direct connection, or through a hub.
              Let's start with a easy-to-setup share, that you can easily set up with 2 dream box help me
              • chumu10
                • Oct 2008
                need dream box 2 sharing card
                • zaf786
                  • 327
                  Hi Guys and Gals
                  Hi try this it should work for you it,s running perfect for me transfer files in correct directory remove evocamd in usr/bin which is christmas fix and replace with this one extract it first do the same with scripts and replace them in USR/LTEMU and chmod 755 and reboot your box and restrt cam might need to restart your box again
                  1***usr/bin evocamd_217a chmod 755
                  2***usr/LTEMU CAM_evocamd_217.sh and current_CAM chmod 755
