Which satellite cable
  • RSMULLEN
    • Jun 2009
    Hi
    just wondering if the coax cable that feeds the box makes a differance to the picture quality. If so whats the best one to get and from where?
    cheers.
  • unadkat
    • 340
    Originally posted by RSMULLEN
    Hi
    cheers.
    if you want a Sat cable then you would be intially looking at a Rg6 cable which is 75ohm's or higher otherwise you will face freezing and so on
    I would get them from a SAT shop or even Ebay as I have bought sat cables from them and they worked just fine
    regards
    unadkat
    • av2008
      • 156
      Hi
      cheers.
      Its more signal/strength quality than picture quality, as im sure u know, u either get or dont get a stable signal with digital. theres no in-betweens. So yes in a way, IE better cable will mean less rain fade.
      • cactikid
        • 12017
        also using cheap cables will give you interference as in not properly shielded.
