ddigital box only fta
  • smoggie
    • 863
    Hi, 1st time i have had a look at one these boxes. Only getting fta atm. i have flashed 2007 bin, rescanned chanels and in menu the pressed 2580 which said enable channel.I have presumed this is to enable the emu. I then reflashed the updated firmware but still cant get pemium channels. software version is d_digital v2.2 03/03/2008. I have varoius threads here and there to get me this far but i'm thinkin i've missed something stupid
  • satsmo
    • 6397
    You need this later fw version smoggie 4shared.com - online file sharing and storage - download DD UK Fix 041208.rar The one you are currently using was pre the April ROM change if it is the unpatched version you are using?Then enable emu as you have done above.
    • smoggie
      • 863
      cheers satsmo, will try..thought the one i was using was the latest
      • smoggie
        • 863
        ok, tried that file and still only fta. went through everything again.
        1. reflash 2007 firmware,go to menu, press 8520 and disable channel(presume this is the emu)
        2. scan for channels,go to menu press 8520 and enable channel
        3. reflash the file that satsmo gave link and still getting fta only.
        on this image you can go to menu, press 8888 to enable/disable channel. system info showing 03/03/2008, d digital v2.2
        • satsmo
          • 6397
          Are you in a 3.7 area? If so try manual key entry, it may require another patch.
          The steps you have taken are correct as the latest firmware version does not allow access to the CAS menu. Turn the power off completely for a minute, power back up and leave it on a scrambled channel. This has kicked the emu in before.
          • smoggie
            • 863
            hi satsmo, cheers for help so far. i have done a manual key entry and the channels have now cleared. Wonder why its not autoupdating.Out of curiosity i went to menu and pressed 8888 to disable channel and encrypted channels dont work, menu 8888 again to enable channel they all work again
            • smoggie
              • 863
              oh forgot to say that i'm in teesside ntl area
